safety loop question---
Old May 7, 2003 | 12:16 PM
HEVYRESQ's Avatar
Question safety loop question---
Buying one this week...just wanted to know.....
1) Which seller/design is made to install without dropping the drive shaft
2) Which design is strictly bolt on..(no welding)
3) If any of them meet both of the above.....
Thanks in advance
Old May 7, 2003 | 12:32 PM
soap's Avatar
Re: safety loop question---
Thanks in advance
Get ahold of PSP or JLP........both fit your criteria.
--Joe
LIGHTNINROD's Avatar
1. PSP and JLP
2. Same as '1'
There may be more but those two are ones I'm familiar with.
Dan
Old May 7, 2003 | 03:06 PM
Tim Skelton's Avatar
I would not let this affect your decision in any way. Four bolts hold the drive shaft on in the rear. It's light as a feather. Removal and replacement takes literally five minutes.
Old May 7, 2003 | 03:11 PM
SpankDog's Avatar
Banned
Re: Re: safety loop question---
wow I never knew that. I guess we all assume that its a big job.....as did i. thanks
Old May 7, 2003 | 04:47 PM
HEVYRESQ's Avatar
Yea...what he said.....thanks for the info!
Old May 7, 2003 | 05:24 PM
If you're going to consider dropping the d/s, then this is what you want:
http://metco-inc.com/ford_lightning_...safetyloop.htm
Dan
Old May 7, 2003 | 05:27 PM
Probleminfected's Avatar
remember to mark the drive shaft before you remove it, so you can re-install it in the same place
some come with a mark already there, if not put your own
