Need some tips
Old May 3, 2003 | 01:14 PM
01svtL's Avatar
Need some tips
whats goin on guys. i just installed the dual magnaflow with an xpipe from JDM and love the sound. Now i need some nice 3.5 " tips to be stickin out though. where would yall suggest finding a nice set of tips that will fit the stock tailpipes? if i need to replace the stock tailpipes also, where to i find a good set of these? basically i want the same look as stock just in a 3.5" stainless steel or chrome. thanks in advance.
Old May 3, 2003 | 01:22 PM
Ayrton's Avatar
You can get nice double walled tips here. http://www.thermalrd.com/products/tips.htm
Old May 3, 2003 | 01:51 PM
01svtL's Avatar
Can i fit two 4" tips in there? It looks like i can only get like a 6" long tip and thats pushing it. Is it the 15degree cut that i need?
Old May 3, 2003 | 03:35 PM
cyntaxx's Avatar
http://www.bestautopartsonline.com/tips3.htm
I would recommend 18 inch long 45 degree slash cut truck/suv tips. 2.5 in/3.5 or 4 out
Old May 4, 2003 | 01:58 AM
01svtL's Avatar
cyntaxx . . .when i got my mufflers installed the welder said i needed like a 6" long tip at themost. How would he weld on an 18". there would have to be some bending involved there because the mufflers themselves are only like 18" away from the cutout in the ground effect. how would he install them?
thanks for the info
Old May 4, 2003 | 02:05 AM
cyntaxx's Avatar
Well, the way I plan on doing it is to have the tips stick out about an inch or two. I run straight pipes so length is not a problem as I will just cut the pipes until everything fits. You could try that, depending on how much room you have to work with. If you are running into the muffler before you get everything to fit, I dunno what you would have to do....
Good luck...
Old May 4, 2003 | 03:51 AM
SLICK0478's Avatar
I am running 4" - 4.5" slash cuttips I think they are 14-18" long they will fit fine as long as the muffler(s) are up front the biggest problem is streching the pipe to fit the tip you have to make alot of passes with the weld to fill the gap from a 2.5" pipe going into the tip mine came out alittle messy but it is all stainless welds, pipe, ect so it still looks neat plus it is underneith the truck anyway
I will try to measure the exact tip length tomorrow and get back to you I believe they are magnaflo stainless tips
Hope this helps
Slick
Old May 4, 2003 | 12:30 PM
01svtL's Avatar
alright man thanks alot. i like the 18" magnaflow stainless tips the best i just cant figure how they will work out. thanks for checking for me though.
lata
Old May 4, 2003 | 05:51 PM
SLICK0478's Avatar
They are 14" I know you can cut them with a nice band saw if you can't get the shorter ones it will look like a factory cut if you have a band saw
Goog luck
Slick
Old May 4, 2003 | 06:14 PM
cyntaxx's Avatar
Where are you guys seeing 14" long ones? I'm only seeing 22" or 18"...
