Looking for advice on an air filter
It's time to give my 03 some upgrades and I'm wondering if anyone is using PSP's FASTair and what they think of it? If not, if you're using a system you like let me know
darreli
I just ordered a Fastair system from Sal hope it turns out to be worth what everyone said it was? Just make sure you order the air filter with the Fastair. The Fastair is just an upgrade. I found out the hard way and almost didn't get a filter. Go figure? Hope this helps.
darrel,
I'm going with a S&B Cold-Air Pwr Stack from chikenears ...
http://www.chikenearsengineering.com/filter.htm
I hear you get a coupla' more lbs. of boost, better mpg and you REALLY hear the S/C !
Hurry up, FedEx !
Ronald
Hurry up, FedEx !
Ronald
I've used two different 'cold air' kits. IMO, the Fast Air is the better design.
http://198.65.157.241/forums/showthr...ht=intake+temp
Dan
Dan
I'd save yourself about $200 and just modify the stock box. You can get a K&N drop in filter, cut out the bottom of the box and leave it at that or you can make a home made ram air setup with the stock box. Either way saves you a bunch of money and it gives you noticable gains too. I did it last night and gained 2 #'s of boost on the stock gauge, and thats without the K&N. Not the most accurate gauge in the world but it stil shows there was an increase.
