Easiest way to replace thermostat?
Old Apr 30, 2003 | 04:15 PM
seidler's Avatar
I am going to replace my thermostat tonight with a 160. Are there any tricks or anything I should be aware of before I do it?
Old Apr 30, 2003 | 04:20 PM
SVTBOY's Avatar
pretty easy actually,just have to unbolt the 1 bracket by the housing to get it out of the way,thats the only little thing i can think of,only took me 45 minutes,have fun!!
Old Apr 30, 2003 | 04:28 PM
cpeapea's Avatar
took me 5 min, just uses two bolts that holds the housing, and a couple for that bracket on top
Old Apr 30, 2003 | 07:40 PM
LIGHTNINROD's Avatar
Wait! Before you unbolt the housing, get a hose and attach it to the drain nipple and drain about 1.5-2 gals of coolant out into a clean container. You won't spill any on to the plugs that way. Just pour it back into the reservoir when you've put the new 'stat in.
Btw, note where the O-ring is when you remove it. It goes back on the top of the 'stat so the housing can seal the opening.
Dan
Old Apr 30, 2003 | 08:19 PM
seidler's Avatar
It was easy. I just moved the bracket slightly and yes, it did spill about 1/2 gallon of antifreeze. I just flushed the engine well and added more to the resevoir. Now I will have to wait and see if it runs any better at the track this weekend.
