All the bolt stuff only went 12.96@104
Old Apr 28, 2003 | 09:10 PM
conleymotorspts's Avatar
I'm new to the site I bought my 2001 L from HIGHROLLER last September After I sold my 99 L . Runner upped with the 99 at cordova last year any way I'm very disappointed with my times. list of mods long tube headers ft valvebody 8pound pulley accufab throttlebody ported upper jdm airfilter kit 15inch bogarts with M/T 12.5x28 etstreets with a jlp tune feel free to give your opinions.
Old Apr 28, 2003 | 09:12 PM
LightningTuner's Avatar
Well, the problem is obvious, you don't have any PSP parts on that list .
Old Apr 28, 2003 | 09:15 PM
SVT_KY's Avatar
Re: All the bolt stuff only went 12.96@104
As someone told me once, there jest aren't any
Go-Fast parts in that list ...
BigBoy_99's Avatar
Can I see ur mod list to get
10.48@ 131.2 mph 1.51 60ft
Old Apr 28, 2003 | 09:17 PM
soap's Avatar
Don't feel bad........Matt's truck was always a POS
--Joe
Old Apr 28, 2003 | 09:18 PM
Jeff's Bolt's Avatar
Sal said it!!
I went a 13.00 104mph on F1s with 4# lower on the street
side of the chip(PSP).
Jeff
J15BIG's Avatar
how was your 60ft time and what were the conditions and altitude?
Old Apr 28, 2003 | 09:21 PM
Coldie's Avatar
60' time?
What kind of 60' times are you getting?
Any traction bars?
what kind of speed at the traps?
what temperature at the track?
elevation?
You're right, an 8lb chip n pulley should run better than 12.9
Old Apr 28, 2003 | 09:23 PM
Chainsaw13's Avatar
From: Cuttin' Heads with Jack Butler at the CrossRoads!
Did you forget to unhook the trailer with your other race vehicle on it?
Old Apr 28, 2003 | 09:24 PM
I guess I just need to talk to johnny about my chip program at columbus this weekend .
Old Apr 28, 2003 | 09:28 PM
BufordTJustice's Avatar
More Info needed. 60' time? Weather? Race experience? Did you mod after purchase? I'm assuming you bought as is from HIGH ROLLER? A quick perusal of the NLOC website reveals the following re HIGH ROLLER:
77 HIGH ROLLER -------- 1.800, 12.490 @ 109.40 (01, Silver) CLTWD
Based on this info, you should not have fallen off this much, weather or what not. Something be wrong SON! The MPH tells the story here. Check the plugs, gas, fuel filter to start. Good luck.
BTJ
Old Apr 28, 2003 | 09:30 PM
temp was in the upper 60's best 60ft. was 1.83 best mph 104.38 the mph is telling me I'm not making the power I should be . spun a little bit but not enought to kill the mph that bad.
Old Apr 28, 2003 | 09:34 PM
matt took of his mods except headers , electric fan I added everything else.
Old Apr 28, 2003 | 09:36 PM
An 8 lb pulley creates huge amounts of heat. If you don't have some kind of add on fluid cooler, it's going to hurt things for sure. If I recall correctly, Matt ran that 12.49 with a 4 lb lower pulley and I am pretty sure it was on the street side of his PSP chip, and also on drag radials. I think that's correct, Matt can verify.
03LightninRocks's Avatar
Something doesn't sound right with the times. Can you post a copy of the slip? Maybe we can see where you lost some time.
An 8lb with a chip should be doing alot more than that.
Check out my sig for what mine is running with the 6lb. I weigh in at 250 lbs, when my son drives it, he can knock a tenth off my time due to his weight of 130 lbs.
Rocks
