What’s causing the bolts to round off on the lower pulleys?
Old Apr 28, 2003 | 06:29 PM
69stangscj's Avatar
Registered User
I don’t have an after market pulley on my truck so I’m unfamiliar with the set up. When you change the lower pulley does a new “soft” bolt come with it causing it to round off? Or does the original bolt freeze up when installed with an after market pulley?
Also the ones that are rounding off, are they coming from a specific vender? Just trying to think ahead here guys, I’d like to not have the same headache if I can avoid it.
Old Apr 28, 2003 | 06:37 PM
SpankDog's Avatar
Banned
Just get an uncaged pulley and you don't have to worry about it.
Old Apr 28, 2003 | 06:43 PM
Silver_2000's Avatar
In fairness the stock pulley is often a bitch to get off.
The cageless pulleys dont have the same method of attaching to the crank so they dont have the same issues as the caged pulleys
Doug
Old Apr 28, 2003 | 06:52 PM
SpankDog's Avatar
Banned
My stock pulley came right off, that huge allen head works nicely, maybe JDM should make theirs like that.......anyone had problems getting a stock pulley off?
Old Apr 28, 2003 | 06:57 PM
I had the dealer destroy 2 after market pulleys. In a long heart to heart with the Mechanics after-wards ( over a 12 pack ) they admitted that even the Stock ones are tough to remove.
I have also seen aftermarket installers struggle with the occasional stock one as well
Old Apr 28, 2003 | 07:01 PM
ST.ELMO'SFIRE's Avatar
the SVT mechanic that took my stocker off said it was a pain to get off, but added that some come off easily and some don't
Old Apr 28, 2003 | 07:27 PM
retics4me's Avatar
Doug
but usually come off in one peice
Old Apr 28, 2003 | 08:36 PM
69stangscj's Avatar
Registered User
not sure what everyone means by "caged pulley"? Anyone have a pic?
Old Apr 28, 2003 | 09:10 PM
SVT_KY's Avatar
Ayup ... There is a tripod like support device that bolts to the
block and supports a bearing. In the non-caged types, all
the pulley does is bolt to the harmonic balancer.
Old May 3, 2003 | 09:48 PM
69stangscj's Avatar
Registered User
Thanks for that pic SVT_KY
Old May 4, 2003 | 07:50 AM
Lightningquick's Avatar
My 02 came off nice and easy.The (Ford) mechanic who took off the stock one on my 00 when changing my motor over got a couple of free paid days out of work along with like 12 stitches and a concusion when the breaker bar he was using broke and smashed his forehead into peices I used a cageless pully on that one and I just did again.Im not into racing so I have no need for an interchangeable one and i cetainly dont need a caged one to begin with.Im pretty confident that I wont be living anymore when a failure comes from running a uncaged compare to a caged.
And if you wanted to change your pully,Changing an uncaged is the same as changing a swappable caged once you get the stocker off..02 except there is only 3 bolts instead of 6 on the uncaged
Im sure the cage serves it purpose but with all the headaches,problems and price,i dont see why anyone would go that route.
Old May 4, 2003 | 08:17 AM
Rob_02Lightning's Avatar
My Stock caged pulley came right off for me,
I installed UN-CAGED after seeing all the problems with aftermarket Caged pulley's coming off.
Old May 4, 2003 | 08:25 AM
JewishLightning's Avatar
The lower pulley system from JDM is the one that has the problem. The bolt is a low grade mild steel. It should be a grade 8 bolt. I'd recommend buying the pulley system from Razors Edge Motorspots. You can interchange the pulleys as well from 2-6. The main pulley body bolts on using 3 small allen bolts.
Old May 4, 2003 | 08:36 AM
yysenhimer's Avatar
Looks and feels like brass to me
Old May 4, 2003 | 10:05 AM
dogleg's Avatar
Yea, when you change these they become a throw away part. JDM will repair & upgrade it for you for anohter $175. The new one will not have this problem. It would have been nice if he would have corrected this mistake for free.
Dogleg
