PCV Valve Question
Old Apr 27, 2003 | 09:59 PM
paul12's Avatar
PCV Valve Question
I am planning on replacing my pcv valve with the EV-98-B unit. I am trying to stop the oil flow. Is there just one pcv valve? I noticed two hoses feeding in the bottom of the boot. Where exactly is it located. TIA
Old Apr 27, 2003 | 10:15 PM
Boltittome's Avatar
Hi Paul,, yes i just did this last week still evaluating... that is the same one as the 03 Cobras,, and yes i think there is only 1 (pass side) the new one will not let you blow through it,, only blows one way,, so we will see,,,
Old Apr 28, 2003 | 02:11 AM
QKSILVR's Avatar
And where does this one go??
Old Apr 28, 2003 | 03:06 AM
cyntaxx's Avatar
Jason:
Hope this helps.
Old Apr 28, 2003 | 03:09 AM
QKSILVR's Avatar
Thanks Charles. Just wanted to make sure I put it in the right one.
Old Apr 28, 2003 | 08:18 AM
silverSVTruck's Avatar
Thumbs down
My experience is this: I got the oil separator from Razors Edge motor sports and installed it and it's been working fine, after hearing about the PCV System I thought "what the hell I'll try that one". I purchased the PVC system and I must say it was easy to install and undetectable, I was about to remove the REM separator and thought that it might be nice to leave it in and see how well the other one worked. Well I’m still getting oil in the REM separator! I guess that I will continue to use both.
Old Apr 28, 2003 | 09:54 AM
paul12's Avatar
Thanks alot charles! I just wanted to make sure it was a simple as that.
