Drag Race Trivia
Drag Race Trivia
Here is some Drag Race Trivia for you from Bob Otto.
> For you gear heads out there!!!
> Top Fuel Dragster Trivia
> One TF dragster's 500-inch Hemi makes more horsepower than the first 8
rows at the Daytona 500.
> Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro
per
second, the same rate of fuel consumption as a fully loaded 747 but with 4
times the energy volume.
> A stock hemi will not produce enough power to drive the dragster's
supercharger.
> Even with nearly 3000 CFM of air being rammed in by the supercharger on
overdrive, the fuel mixture is compressed into nearly-solid form before
ignition. Cylinders run on the verge of hydraulic lock.
> Dual magnetos apply 44 amps to each spark plug. This is the output of an
arc welder in each cylinder.
> At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the flame
front of nitromethane measures 7050 degrees F.
> Nitromethane burns yellow. The spectacular white flame seen above the
stacks at night is raw burning hydrogen, dissociated from atmospheric water
vapor by the searing exhaust gases.
> Spark plug electrodes are totally consumed during a pass. After ½ way,
the
engine is dieseling from compression - plus the glow of exhaust valves at
1400 degrees F. The engine can only be shut down by cutting the fuel flow.
> If spark momentarily fails early in the run, unburned nitro builds up in
those cylinders and then explodes with a force that can blow cylinder heads
off the block in pieces or split the block in half.
> To exceed 300 mph in 4.5 seconds dragsters must accelerate at an average
of over 4G's. But in reaching 200 mph well before 1/2 track, launch
acceleration is closer to 8G's.
> If all the equipment is paid off, the crew worked for free, and for once
NOTHING BLOWS UP, each run costs $1000.00 per second.
> Dragsters reach over 300 miles per hour before you have completed reading
this sentence.
> Top Fuel Engines turn ONLY 540 revolutions from light to light!
> The redline is actually quite high at 9500rpm
> The current TF dragster elapsed time record is 4.477 seconds for the
quarter mile (06/02/01 Kenny Bernstein)
> Putting all of this in perspective:
> You are driving an average Lingenfelter powered "twin-turbo" Corvette.
Over a mile up the road, a Top Fuel dragster is staged and ready to launch
down a quarter mile strip as you pass. You have the advantage of a flying
start, but you still run the 'Vette hard up through the gears and blast
across the starting line and past the dragster at an honest 200 mph. At
this
moment, the dragster launches and starts after you. You keep your foot hard
down, but you hear an incredibly brutal whine that sears your eardrums and
within seconds the dragster catches and passes you. He beats you to the
finish line, a quarter mile away from where you passed him. That, folks, is
acceleration.
> Think about it, from a standing start, this phenomenal machine has
spotted
you 200mph and not only caught, but nearly blasted you off the road when he
passed you within a mere 1320 feet.
> Now....., tell me about the time you spun the wheels and laid rubber on
dry concrete.
per
supercharger.
the
this sentence.
this
acceleration.
spotted
dry concrete.
Don't take it wrong. I was not flaming. Just got the E-mail and found it interesting enough to pass on.
I tried the math on 9,500 divided by 4.5 and got 2111 ???
It is amazing technology and I like the supercharger facts. Maybe some experts can scrutinize these facts.
I agree it is so cool that we are a active participant rather than just a wishfull observer.
