Suspension questions among others
Old Apr 25, 2003 | 03:58 PM
ogieogilthorpe's Avatar
Question Suspension questions among others
OK I' gonna get some shackles and some drop springs here soon. I cannot stand the gap anymore. I figure I'd go with a 2/3 drop. Here are some questions:
-Will I get bad camber and excessive tire wear with lowering the L? I will need a realignment correct?
-What is the best moderatley priced setup?
I eventually want to go to 20in. wheels. Will I be fine if I keep the 2/3 setup?
OK people fire away.
Old Apr 25, 2003 | 04:43 PM
cyntaxx's Avatar
a 2/3 drop with 20s is fine...
Old Apr 25, 2003 | 06:13 PM
TorontoF150's Avatar
Make sure you get the NAPA cam bolt kit so you can adjust your camber back to spec.
Some say this cam bolt kit is very cheap, and recommend the Ford kit. Either way, a camber kit is needed.
Good luck, and be sure to post some pics
