160 degree themostat
Old Apr 24, 2003 | 10:43 PM
01FordLightning's Avatar
i needed to know if i could reuse the gasket with the old one also i wonted to know if i needed to drain the coolant
Old Apr 24, 2003 | 10:58 PM
Probleminfected's Avatar
yes, no
Old Apr 24, 2003 | 11:52 PM
Thanks for the info!!!!!!
Old Apr 25, 2003 | 08:47 AM
LIGHTNINROD's Avatar
Yes.
Yes--but only 1.5-2 gals. By doing that, you will get no spillage of coolant that may run down onto your plug(s). Attach a vacuum or fuel/heater hose on the drainc0ck and direct it into a low-sided pan. Use a clean receptacle and reuse that coolant when done with the install.
Dan
