What is a good PSI to run F1's at the track
hey guys, im going to the track again tomorrow and im gonna swap out my 20's in the rear, and put on the 18's w/ F1's on them.... what is a good PSI to run them at for traction and drivibility???
I leave mine alone - run them at street pressure. I was able to cut 1.85 60' all day long at Norwalk towards the end of last year... on the F1's (there were a few from here that witnessed this). All they need is cleaned off a bit, and roll into the throttle... works very well.
Track prep has a lot to do with the different pressures you're seeing people post.
I've run them typically at 28 PSI and I've done horribly (2.1 best) at one track and a best of 1.84 at another.
I would start high and reduce from there depending on the resulting 60'.
Good luck!
Dan
Good luck!
Dan
