check engine light after rem powerintake
Old Apr 21, 2003 | 10:00 PM
Yeller916's Avatar
howdy, i just installed my rem filter and power tube today and now my check engine light is on? its an 03...whats the deal and how do i get it off? thanks
garrett
Old Apr 21, 2003 | 10:06 PM
400HPHD's Avatar
You can get it off by disconnecting the negative terminal, turning off your headlights for 15 minutes and reconnecting...you should of done this after the mod!!!
Old Apr 21, 2003 | 10:15 PM
Scott Dunn's Avatar
Just disconect the neg. batt. term. and make sure the AIT sensor is plugged in. If you just changed the boot the only thing that can set is the AIT, which is common.
Scott
PS I usually diconect for about 90 sec. that will stop MIL.
Old Apr 21, 2003 | 11:00 PM
tallimeca's Avatar
vaccum lines
make sure when you put the vaccum lines on the tube, the one that connects to the drivers side cover didn't pull out.
