The PCV Fix ""Does Work""
Old Apr 19, 2003 | 09:41 PM
Rob_02Lightning's Avatar
Thumbs up The PCV Fix ""Does Work""
As some know, I have the PCV Fix that gives the New PCV and a second reverse flow PCV for the Drivers Side
Here's the before picture
And here it is today
Clean as a whistle
Thats after a month or 2 of beating it big time, 5 Nitrous Runs at Cecil last weekend, 2 Gas Runs today at my Local Track, and many Nights of juicing it on the streets, and about a month or so of daily driving
Old Apr 19, 2003 | 09:43 PM
Unfortunatly I wish I could say the same for the inside
Even the inside is better than before as promised though
I guess I should consider putting the Seperator back on,
But at least half my oil problem went away
Old Apr 19, 2003 | 11:04 PM
cyntaxx's Avatar
So far I've just used the EV-98-B PCV valve and I've seen no oil in my intake. It's been about 1000 miles...
Old Apr 20, 2003 | 10:25 AM
svtdvm's Avatar
So there is no complete fix?
Only the oil from the front of the intake can be stopped?
Old Apr 20, 2003 | 10:49 AM
Groundstrike's Avatar
Hey Cyntaxx did you just replace the stock pcv valve with this one? Thanks...
Old Apr 20, 2003 | 11:09 AM
Crash-n-Burn's Avatar
I use it also and it seems to have stopped the oil problem.
Old Apr 20, 2003 | 12:34 PM
cyntaxx's Avatar
Yep. Although I haven't taken the entire TB and boot assembly out to check, but just taking a close peak at it shows no sign of oil.
Old Apr 20, 2003 | 03:39 PM
Nathan's Avatar
where do you get this 'fixed' part?
Old Apr 20, 2003 | 03:44 PM
dirtchicken's Avatar
Nathan, I'm guessing that's a Ford part number.
Old Apr 20, 2003 | 03:53 PM
cyntaxx's Avatar
Yep it's a 5 dollar (or less) Ford part. Got it at my dealership...was in stock too.
EV-98-B
Old Apr 20, 2003 | 03:56 PM
I'm guessing that the one that cyntaxx has allows vapors to flow only ONE direction. Wasn't it Rob_02 that said he could blow both ways through the stock PCV??
Old Apr 20, 2003 | 05:20 PM
LIGHTNINROD's Avatar
The OEM L PCV valve will not 'seal' in either direction. Take it out and hold it up to the light or blow thru it in either direction. It's a 'restriction' only and allows for 'flow' into or out of the crankcase. Why? I don't know but the other PCV will allow flow in only one direction
Dan
Old Apr 20, 2003 | 05:25 PM
Thanks Lightninrod. I'll be picking one up shortly.
