So hard to hear detonation over the blower and my exhaust
How else can I know if everything's alright? I have a 4# lower and a pro m 80 mm and Paul at rem said it's hard to tune for.
He says the pro m sometimers throughs more timing at ya sometimes or even less, how is that? Should I just go back to the stock 80mm and air box if I don't upgrade to the 90mm?
I dont want anything to happen to my motor and I want a safe tune on my chip. The last time I hear detonation was on my way home around 1am and it was cold out. The thermometer in my truck read ice and then 38 degrees I think was the highest it read. So I took it easy and I got it home and that was that. I called paul and he said my timing was at 18 or 19 and he said he can lower the timing and add a little more fuel...
BUT sense it's been nice out 70-80 degrees here I can't hear any detonation. I've tried getting on it and i've been at wot in 2nd and 3rd gear and it pulled hard and felt good. And sounded ok... Should I keep the program I have or get a reburn and go lower timing and risk having a "sled" but keep I'll my rods together....
Any advise b4 I go to the track Tuesday? Check my plugs and can i see how the detonation was or no? Thanks, Shane
That is a lot of timing for 93 octane, but I'm not a tuner or something. The chip I'm running right now is 13.5° timing on the street side(93 octane) with 15psi boost(it also works well with a 100shot.)
Originally posted by alphadoggy
Pro-M and chip destroyed my first motor. Now I have a 90mm and a different chip (and tuner) on this motor. No problems so far.
Originally posted by ShaneMcKenna203
what exactly is wrong with the pro m?
I live in Illinois and I run 93 octane all the time. What else...
The pro M I am going to try to update to the 90. I'm just wondering if I'm safe to run this tuesday. What should my plugs look like if I look at one. And what one should I look at? (whats the leanest cylender #5?) About the pro M not being consistant, I've heard that also. I got it for free, and it was the first thing I threw on my truck, so when I get the chance to upgrade to the ford 90 I will. I just dont want to blow anything up Tuesday, should I lower some timing AND get the 90 mm or lower timing and run with pro M, or sit out and get a reburn and go another day....
whast should my timing be at with the 90mm 16-17 or so sound ok for a conservative program? I just think 19 is way to high.
My question is can I run this tuesady 2 or 3 times with the timing where it is on the pro M?
You might be ok with the pro-m and you might not. They are just to inconsistent, My A/F ratio was way to lean due to the
pro-m. Now i'm back to the stock 80mm. At least your tuner will admit the PRO-M can be dangerous. I had to prove it to mine, same meter on two different trucks on dyno, A/F's way to lean.
There is no way to tell if that ammount of timing is safe, it all depends on how hot your meter is. Thats why you should get the 90mm they are all the same. If you dont hear anything id say your probably ok. Your check engine light shoulndt come on with a chip of a pro-m though.
