Computer Reset ? opinions
Old Apr 16, 2003 | 05:37 AM
SLICK0478's Avatar
Are you guys reseting the Comp when you goto the track ?
Does it really make a differance if you do?
Those with chipped trucks does manufacturer of chip make a diff whether you reset or not?
Thanks in advance
Slick
P.S. Gonna go to E-town(NJ) Fri if weather holds up
Old Apr 16, 2003 | 08:10 AM
SVT_KY's Avatar
I think i read sopmewhere that it resets the adaptive fuel tables.
But at WOT, I think it is just reading the tuner tables for the
fuel settings.
Just in case, I reset mine ... Since I switch to the race program anyhow.
Tuners?
Old Apr 16, 2003 | 08:30 AM
LIGHTNINROD's Avatar
Yes, reset your PCM at the track. Sal(and I think the other tuners too) says to do it.
Dan
Old Apr 16, 2003 | 08:37 AM
01Lightning's Avatar
Only reset your computer if you are running a chip... resetting if you are not running a chip could have adverse effects until the computer re-adjusts. If you do not have a chip and have ever had your battery disconnected, you probably noticed it takes a day or two for the truck to start running "normal".
Old Apr 16, 2003 | 10:53 AM
SLICK0478's Avatar
THANKS
So only chipped trucks should do this no matter what brand of chip also after every run or just before the first run @ track
Thanks again all
Slick
