Gauges
Old Apr 15, 2003 | 08:45 PM
therealgeronimo's Avatar
Gauges
How do I hook up my trans temp gauge, boost gauge (most accurate hose to tap into) and air fuel gauge? I should have them all in tommorrow. All are the autometer gauges, phantom series. Any help or links to how-tos would be appreciated. If no one has a how to I will make one as I go along. Thanks!
Old Apr 17, 2003 | 01:00 AM
SpankDog's Avatar
Banned
A/F gauge taps into the black wire on the drivers side front O2 sensor.....here
Transmission temp sender goes in the drivers side of the tranny. Theres a brass plug you remove and then thread in the sender, a tiny bit of fluid might drip out. See here.......
The boost gauge hooks up under the dash, there should be a vacuum line under the steering column if i remember right. Somewhere along the line is a in-line fitting, just unplug and hook up your gauge or get a small T and keep the stock boost gauge.
