Why are my dyno #'s so low?
I think a motor with ported heads/aftermarket cams should be closer to 500/600, even with the stock blower. Then again, you do have to use crappy gas out there, so who knows. Do you have modmax, crower, or comp cams?
Originally posted by DanimalSVT
I have a '01 w/ 20's and they are heavy! I put down 340 RWHP & 442 RWTQ in 2nd Gear. I know '02's and '03's w/ the stock 18's that put down ~360 RWHP in 3rd gear.
If you are measuring horsepower with a roller inertia dyno (i.e. dynojet) than wheel inertia makes a difference. Horsepower is calculated by the acceleration of the drum of a know inertia. The heavier the rims the more energy required to spin them, the less of the energy goes to accelerating the dyno drum.
Hope this helps!
Hope this helps!
that is a very good point
Originally posted by Cali L
What was your final timing after the 4 reductions? That will help compare apples to apples with my numbers. Are those corrected numbers on a dynojet? Further apples to apples here. I'm on Cali crap fuel and got the numbers in my sig. Less timing and richer A/F than a lot that I've seen and no detonation. With all those goodies
it does seem a little low.
BD
BD
Dave
Dave
