Flex-a-lite wiring?
Old Apr 13, 2003 | 01:54 AM
Dageon's Avatar
Question Flex-a-lite wiring?
I have the flex-a-lite e-fans. I have everything hooked up but the wire running to the ac compressor. Can someone tell me what wire from the compressor turns on the clutch compressor? I don't have a multimeter handy and not sure what wire to tap. Thanks
Old Apr 13, 2003 | 09:22 AM
ShadowBolt's Avatar
No problem, it's right next to the battery. I hooked mine up to a wire on the pressure switch on the freon line going from the compressor to the evaporator. It is a purple wire. Use a scotch-lock. Works perfect. Only problem with this fan is it is loud!
Jerry
Old Apr 13, 2003 | 09:23 AM
ShadowBolt's Avatar
If you need more help I'm right down the road in Georgetown. Call me if you need to 259-4930.
Jerry
Old Apr 14, 2003 | 06:37 PM
Dageon's Avatar
Thanks Jerry, I will take a look at it tonight when I get off work. I hope, getting off work at 2am is no fun. Thanks again
Old Apr 14, 2003 | 06:41 PM
user 6297924234's Avatar
Damon,
What's worse?
Leaving at 2am, or waking up at 2am??
How's your L coming along?
Old Apr 14, 2003 | 08:00 PM
Dageon's Avatar
Ricky, whats up man? I agree it's a lot easier to go to sleep at 2 then to wake up. I don't miss kicking the rooster in the a$$ in the mornings. Your defenitly a trooper for working those hours.
Old Apr 17, 2003 | 12:38 AM
Dageon's Avatar
Well I can't seem to locate this purple wire anywhere. Can some help a brother out here. I need to find out where to connect to the AC.
Old Apr 17, 2003 | 12:43 AM
Edward's Avatar
Damn! 2am? Ricky what exactly is so important that it has to be done at 2am? I'm sorry I missed you guys this past Saturday; but my uncle died Friday morning after a 2 year battle with cancer. I hope to see you guys next month. Are any of you going down to S.A. for the dyno day that Nathan posted? I'm pretty sure I'll be there.
Later,
Edward
Old Apr 17, 2003 | 08:18 AM
ShadowBolt's Avatar
Call me at work and I will talk you threw it....no problem.
759-1026
Jerry
Old Apr 17, 2003 | 06:12 PM
Dageon's Avatar
Jerry your the best.
I appreciate all your help. It was nice to talk to you, and I hope to me you soon. Thanks a lot
