My results with a 3" shackle kit
Old Apr 11, 2003 | 09:09 PM
camcojb's Avatar
I installed a 3" shackle kit from JLP a couple of days ago on my 03 Lightning. I dropped exactly 2". I waited a couple of days to post to see if it would change at all. So at this point the 3" shackle is worth 2" on an 03. It did make the truck almost level, maybe 1/2-3/4" higher in the rear.
Jody
Old Apr 11, 2003 | 09:10 PM
99svtlightning's Avatar
2" shackles never give you at true 2" either. You did well to get the full 2.
Old Apr 11, 2003 | 09:17 PM
camcojb's Avatar
I agree, I wasn't complaining. I've just seen several posts asking how much they would give on an 03 so I posted my results. Like you said, since it only affects one end of the spring it will not drop the truck 3" just because the end is extended that much further upward.
Jody
Old Apr 11, 2003 | 09:23 PM
Ayrton's Avatar
You may pick up another half inch, as some of the HD guys have the JLP 3" shackles, and they seemed to pick up a little after a few miles.
Old Apr 11, 2003 | 09:40 PM
LightStruck's Avatar
I've been wondering: Are 3" shackles named that because they are 3" longer than stock? AND- when installed, only ONE end of the spring is located 3" higher than it was--so you don't really get a 3" overall drop???
Old Apr 11, 2003 | 10:15 PM
camcojb's Avatar
That's my guess.
Old Apr 11, 2003 | 10:16 PM
93Cobra's Avatar
looks like a stock 99-02 truck now.
Old Apr 11, 2003 | 10:29 PM
Don's Bolt's Avatar
Jody
The truck looks great. I also checked out your project cars, all I can say is wow.
Old Apr 11, 2003 | 10:36 PM
camcojb's Avatar
Thanks Don, I appreciate it. I'm just a performance nut. This Lightning is going to be a LOT of fun!
Jody
Old Apr 11, 2003 | 11:03 PM
Edward's Avatar
I don't get it. How could a truck "settle" a few days after shackles have been installed? It's steel; it won't stretch anymore. However, I can certainly see how drop springs would settle.
Old Apr 11, 2003 | 11:25 PM
dod racing's Avatar
anyone seen an 03 with a bell tech 2/4? ? I wanna go 2/4 on my '03 and am wondering what everyone suggests
Old Apr 12, 2003 | 12:03 AM
Tim Skelton's Avatar
Sonic blue 03's look great! Especially since you got rid of the farm truck look.
Old Apr 12, 2003 | 11:08 AM
cobra97snake's Avatar
well, when the shackle push's the leaf spring up and puts more stress on it to make it lower, the "settle" part is just when you drive it, it gets use to the stress so it curves down alittle more.... it's hard to explain i guess but you get the idea?? when you first install the shackle the leaf spring kinda looks like a half oval, than after driving it, it kinda goes to more of a half circle....
Old Apr 13, 2003 | 09:36 PM
silverzz28's Avatar
can someone confirm this??? Or at least give me the total length from center bolt hole to center bolt hole.
