Best DOT Approved Slick/DR for a 16x10 Rim?
Im getting myself a set of American Racing Baja 16x10's. Whats the best DOT approved tire to run on them? I want to legally be able to run these tires on the street. Thanks
-Mike
-Mike
M/T ET Streets or Hoosier Quick Time Pro DOT
Hoosier Sizes
28x11.50-16LT Tread Width 10" Recommended Wheel Width 8-10
28x14.50-16LT Tread Width 12" Rec. Width 10-12
Mt E/T Streets Sizes
28x 12.50-16LT Tread width 10.0
26 x 11.50-16LT tread Width 9.7
Both are recommended for 10" wheels
There's also a 26" QTP but the tread width is only 8"
Now for the disclaimer's:
NOT FOR HIGHWAY USE: All Hoosier Racing Tires including DOT labeled Hoosier Racing Tires are designed for racing purposes only on specified racing surfaces and are not to be operated on public roadways. DOT labeled Hoosier Racing Tires meet Department Of Transportation requirements for marking and performance only and are NOT INTENDED FOR HIGHWAY USE. It is unsafe to operate any Hoosier Racing Tire including DOT tires on public roads. The prohibited use of Hoosier Racing Tires on public roadways may result in loss of traction, unexpected loss of vehicle control, or sudden loss of tire pressure, resulting in a vehicle crash and possible injury or death.
WARNING: ET Street tires have passed D.O.T. requirements but have reduced tread depth and compounds designed for racing. Due to the reduced tread depth these tires should be used on dry pavement only and are not suitable for normal highway use!
Hoosier Sizes
Originally posted by MORTIS
Did you guys have to shave down the calipers or modify to fit the 16's or should they be no problem?
16s, No Problem.
Its the 15s you have to modify.
so if your using the american racing baja 16+10s rims whats the differenc between the hoosier 28+14.50 and the 28+11.50 besides the width and witch one should i use because i don't want to buy the wrong stuff for a change
