Problem with Trans Temp Gauge
Old Apr 3, 2003 | 11:51 PM
BADBOLT2's Avatar
I just re-installed my Autometer Gauges in the new truck and as soon as I turned on the key my Trans Temp gauge "buried" to the max.
I went to my local speed shop and they said it sounded like a bad sending unit.I changed it and now the gauge works,although it's reading like 60* too hot.
Last summer even in 120* heat it maxed out at 180*
Now in 80* heat it starts at 110* as soon as I start up, and reads as high as 220*!
I know it's not accurate.Anybody got any ideas??
Are all Autometer electric sending units the same??
Tahnks for any help.
Old Apr 4, 2003 | 02:38 AM
Factory_Tech's Avatar
I'd bet it was the guage itself and not the sending unit, you have to do something pretty extreme to get a tranny over 200 degrees in a forward gear without powerbraking. It's easy to do in reverse, though.
G
Old Apr 4, 2003 | 04:30 AM
VyPeR's Avatar
Maybe a pinched wire or a bad ground somewhere? A multimeter might shed a little light on the subject. I'm not sure exactly how to go about testing an autometer gauge or sending unit, but I'm sure there's a "proper" voltage or resistance that you should be seeing... at least then you can verify whether it's the gauge, wiring, or sender.
Old Apr 4, 2003 | 10:08 AM
BADBOLT2's Avatar
Someone over on NLOC mentioned there are different senders for different gauges i.e. full sweep or half sweep.I'll give Autometer a call.
Thanks!
Old Apr 4, 2003 | 06:50 PM
Neal's Avatar
Cool
HI!... I've always had trouble with "ELECTRICAL" temp gauges. That's why I always use "MECHANICAL" temp gauges now for about the last 10 years. Never had a problem since I switched. Get yourself a "MECHANICAL" tranny temp gauge. More accurate IMO.
