FJO wideband
Old Apr 1, 2003 | 05:40 PM
easterisland's Avatar
FJO wideband
How accurate is it? I'm getting 10.5 at WOT from 2-5K rpm. Anyone have any comments?
Old Apr 1, 2003 | 05:47 PM
Crash-n-Burn's Avatar
Very accurate.A few guys in Florida run them and they are right on with the dyno wide band.
Old Apr 1, 2003 | 05:52 PM
Old Apr 1, 2003 | 05:54 PM
SpankDog's Avatar
Banned
Whats the price on that bad boy?
Old Apr 1, 2003 | 05:56 PM
Well,youre fat,thats for sure.
Old Apr 1, 2003 | 06:02 PM
VyPeR's Avatar
and extremely low on fuel... Service Engine Soon light?
Dale-01L's Avatar
I would think that would lean out quite a bit in gear under a load, no?
I've heard people say going from a dynojet load to the street (full load of truck weight) can raise a/f up to a full point. How far does it jump up from no load to street load?
Would be good info, when yo jump on it on the street let us know what it does....
-Dale
Old Apr 1, 2003 | 06:25 PM
RAN JR's Avatar
That sure is rich, especially since you have no boost. I would think that it would be reading real lean once you let of the throttle.
Old Apr 1, 2003 | 06:45 PM
99svtlightning's Avatar
I would grab a reading at the top of 2nd and 3rd gear under load. That's when they seem to lean out the most. I stay around 11.5:1 to be safe. Where did you get your A/F gauge and how much? I believe AFM sells them for around $500.
Old Apr 1, 2003 | 06:49 PM
Calightnin's Avatar
Mine is always right on when I check it against any other meter.
Old Apr 1, 2003 | 07:27 PM
Ruslow's Avatar
While I was up a JDMs' I cked mine with the one they use and was off almost 1 point mine was showing leaner than theirs.I have fitting in the exhaust on both pipes so we ran them together to see how accurate mine was.Was good up untill WOT then it showed being off.Stan
Old Apr 2, 2003 | 05:48 AM
Flying Mofo's Avatar
Banned
Just a word to the wise. As expensive as those Widebands are, dont drive around with it installed perm. Use it for tuning purposes or else it will burn up. Esp, with the ignition off and power to the module.
Do a 3rd gear pull under full load. Probably best to hit the freeway.
Old Apr 2, 2003 | 11:30 AM
-Dale
That is what it gets WOT 10.5 to 10.8. I just reved it up to get a picture.
Old Apr 2, 2003 | 11:33 AM
Actually I think they use a honda 5 wire sensor. I think they are around $150 or so. Third gear is no problem in town. I just weave in and out of traffic. The roush suspension and KB help with the cops.
Old Apr 2, 2003 | 11:38 AM
01Lightning's Avatar
You reved it to redline while in park?
