Question about Chip and Engine's Redline
Old Mar 29, 2003 | 07:00 AM
Rob_02Lightning's Avatar
Once I had the shift point moved back down to 5250 RPM, and I hated it, Sent it right back the same day to be put back up to 5500. But like I say it's the RPM after the shift that I'm more concerned with. And yes, sometimes depending on How you WOT it (from stop) (from roll) (from downshifting it) etc...
Mine will shift as high as 5600/5700.
Twice now (did it again the other night) when I switch from one program to another program (on the fly) it seems to "not have any shift point OR REV LIMITER for a minute", and it will pin the tach before shifting After a few times of that, it goes back to normal, it's done that differant times with differant Programs from differant tuners.
I call it stretching and testing the Rod's
I got me a good set no doubt
Old Mar 29, 2003 | 11:59 AM
Cobrakid's Avatar
when I put my ET streets on...26 inches tall, the computer reads
the speedo sensor which is thrown up by the shorter tires and
causes the tranny to shift about 400 rpms earlier.
...the result, truck ran the same with ET streets as it did with
the Nittos 28.5 inches shifting at 5350.
So actually my truck had better hook, more gear, 100 lbs less
weight(skinnies on front also) and ran the same b/c the tranny
was short shifting the truck.
....so quit bull*****t!ng, and get Nittos and you'll run 12s all day.
My truck has basically the same stuff as yours will have and runs
12.68@107 with 1.81-1.87 60fts. on a 70* day at sea level.
Goodluck...
Old Mar 29, 2003 | 01:44 PM
TorontoF150's Avatar
I'm gonna try to get the fastest time possible on street tires (F1s), and then move to a drag radial once I get an E-fan, R pump, T/B, headers, etc...
Old Mar 29, 2003 | 04:20 PM
Flying Mofo's Avatar
Banned
Originally posted by cyntaxx
So what's your's at? 5200?
Yes, my shiftpoints are 5250
Old Mar 29, 2003 | 04:25 PM
mrinaldi's Avatar
The best I have run on F1's was a 12.41@111.99mph with 17k miles on the truck....The F1's were in decent shape at the time, but the best 60 foot time I could get out of them was a 1.94...Now at 21k miles they are really shot and won't hook at all anymore....
