garage booboo
Old Mar 26, 2003 | 07:45 PM
Yeller916's Avatar
garage booboo
i pulled in my garage today and i pulled in just a little too far and bumped the wall with the front end and there isjust minor abrasion and a couple of scratches on the bumper...will these buff out or do i have to repaint?
Old Mar 26, 2003 | 07:54 PM
cyntaxx's Avatar
Depends on the damage...
I would just go ahead and get a ghost flame job
and maybe some 20s or 22s to go with the bling
Old Mar 26, 2003 | 07:57 PM
FXDX's Avatar
Try compound followed by polish first. If That doesn't level it, try wet sanding with 1500 grit paper followed by coumpound, polish then wax. Be careful not to cut through the clear coat. The wet-or-dry paper cuts fast. Do not finger sand! Use a back up pad.
Old Mar 27, 2003 | 10:09 AM
Fast Gator's Avatar
And after you get it fix, try this........
Purchase a piece of lumber (2X4 or 4X4), I use a 4X4 and pull the truck in the garage slowly till its right where you want it. Then place the wood in front of the front tires. Then back the truck out of the garage and turn it around, backing up in the driveway. Then take a can of spray paint and "mark" both sides of the wood on the floor. After you have done that, back the truck slowly into the garage until its exactly where you want it. Then place the wood behind the rear tires. Pull the truck out and "mark" the floor again.
Now you have a stopper on the garage floor that can be adjusted whether you back the truck in or pull it in.
Old Mar 27, 2003 | 10:18 AM
Nathan's Avatar
me too
I had a similar incident recently. A clay bar did the trick nicely.
Old Mar 27, 2003 | 10:49 AM
SpankDog's Avatar
Banned
I hang a tennis ball from the ceiling and it hits my windshield when its time for me to stop, works great.
Old Mar 27, 2003 | 11:18 AM
C BROWN's Avatar
Similar thing happened to me; but mine is going to require paint.
Old Mar 27, 2003 | 11:38 AM
MaxTorque02's Avatar
Re: me too
Hmmmm? Never heard of a clay bar taking out scratches. They are great for getting the contaminants off the paint, but usually a scratch remover of some kind is necessary to get out scratches and scuff marks. Meguiars makes an excellent one.
Old Mar 27, 2003 | 11:48 AM
wydopnthrtl's Avatar
Thumbs up
Just this last weekend I hung a tennis ball from the celing too. Only I have it in line with the top of the antenna so it does'nt hang low enough for the kids to swipe at.
WOT
Old Mar 27, 2003 | 01:56 PM
captainoblivious's Avatar
Ditto.
At least it happened now while I'm planning to take it the body shop for other stuff though
Old Mar 27, 2003 | 02:59 PM
cyntaxx's Avatar
WOT
Ahhh tetherball. Brings back memories.
Old Mar 27, 2003 | 03:16 PM
99svtlightning's Avatar
I scratched my wifes Explorer with a contaminated claybar. It must have had something sharp in it. I had a friend wet sound it out and then compound it. Looks good as new now.
Old Mar 27, 2003 | 03:31 PM
PhillipSVT's Avatar
The tennis ball trick work's great in 2 of the 3 garages. The other one is 60' long, so not a lot of worries thier.
