trannny filter?
Old Mar 24, 2003 | 07:48 PM
01FordLightning's Avatar
trannny filter?
I bought a tranny filter at autozone for and I dont know if I need the deep or shallow filter. The box says TF350. It is a factory tech valvle body I dont know if that makes any difference. The instructions say i need a TF325. Will the TF350 work. Thanks
Old Mar 24, 2003 | 08:21 PM
dirtchicken's Avatar
I believe the TF350 is for the deep pan. Can anybody else help out with this??
Old Mar 24, 2003 | 08:35 PM
DennisWeise's Avatar
TF350 (PS1213) for stock pan. TF325 for deep pan.
DW
Old Mar 24, 2003 | 10:01 PM
69stangscj's Avatar
Registered User
This is the Motorcraft 4x4 filter (deep sump), are you going to a deep sump pan?
Old Mar 24, 2003 | 10:27 PM
its the stock pan and is it ok to put in different fluid brand than motocraft but the same kind? thanks for the info Justin
Old Mar 25, 2003 | 05:05 AM
Factory_Tech's Avatar
The stock pan is TF-350, the deep pan is TF-325. You can mix fluid, just amke sure it's MERCON and not, not even maybe, but NOT MERCON V!
Most Mercon is labeled MERCON/ DEXTRON III, which is fine, but do not use a fluid that says it's both MERCON and MERCON V compliant.
G
Old Mar 25, 2003 | 10:44 AM
thanks for the help Justinh
