Is There A Preventative Fix For The Cracking Doors?
Old Mar 24, 2003 | 03:29 PM
HANKFAN's Avatar
My warranty is up in about 2 months and as of right now my doors have no cracks in them but I am worried that in time they will. Does anyone know if Ford has a fix so that my doors won't crack? If so does anyone have the TSB #?
Old Mar 24, 2003 | 04:43 PM
cpeapea's Avatar
uh oh...is this something else i need to worry about?
Old Mar 24, 2003 | 04:49 PM
FastAsL's Avatar
where do the doors crack? and what years have this problem?...chris
Old Mar 24, 2003 | 04:59 PM
jaymz's Avatar
Buy a Chevy or a Dodge?????
But seriously folks, almost every F150 from '97 thru 2000 has these door cracks...just above the radius of the lower rear side-window curve...where the black gasket goes from wide to narrower. Theories abound as to the cause, but when you raise the elec. windows, watch the door panel bulge when the window "tops out." Fatigue gets 'em eventually.
I think Ford implemented some internal door brace in 2001, but I could be wrong about the year. Do a search and you can spend your day reading on this subject.
Old Mar 24, 2003 | 05:57 PM
HANKFAN's Avatar
Thanks for all the info but does anyone know if Ford has a fix to prevent this from happening?
Old Mar 24, 2003 | 06:14 PM
jaymz's Avatar
If you get a responsive dealer who has a clue about the whole issue, then they can remove your door skin and weld in a reinforcing brace, then they can fix the existing crack in the body shop.
Old Mar 24, 2003 | 06:58 PM
HANKFAN's Avatar
I wonder if Ford will fix this problem if it happens to my L after my warranty has expired since this is a known problem?
Old Mar 24, 2003 | 10:57 PM
HANKFAN's Avatar
Old Mar 24, 2003 | 11:03 PM
SpankDog's Avatar
Banned
anyone got any pics of this crack?
Old Mar 24, 2003 | 11:12 PM
2000FordStyle's Avatar
SpankDog,
Theres a pic on this thread.... I had the door crack issue and had the drivers door fixed and a preventative kit in the pass door. The TSB # is also listed in the last post I made on that thread also.
Hope this helps maybe
https://www.f150online.com/forums/sh...ght=door+crack
Old Mar 25, 2003 | 07:06 AM
Jeff's Bolt's Avatar
HANKFAN
My 99 had it and they put on a new door. I think paint is covered for 5 years not sure. Good Luck!!!!
JEFF
