How accurate is your Autometer Boost Gauge?
Old Mar 21, 2003 | 12:31 PM
Flying Mofo's Avatar
Banned
im starting to second guess the accuracy of mine. How about some of you running 4#'s or higher?
Old Mar 21, 2003 | 01:39 PM
dionisio's Avatar
Registered User
I just ordered one. Do you think it's low or high?
Old Mar 21, 2003 | 02:08 PM
SpankDog's Avatar
Banned
Mine reads correctly.....
Old Mar 21, 2003 | 02:18 PM
soap's Avatar
Ditto.
--Joe
Old Mar 21, 2003 | 02:21 PM
Lightning#838's Avatar
Mine reads 14#'s........4# lower + 2# upper =14
Old Mar 21, 2003 | 02:27 PM
LatemodelRacer2's Avatar
my autometer electic reads fine 12- 12.5 with a 4lber. 13 sometimes on 30degree nights.
Old Mar 21, 2003 | 02:29 PM
LightningJMP's Avatar
Mine seems to be correct, just got it installed yesterday and I am seeing right at 12-12.5 with 4lber.
Old Mar 21, 2003 | 02:42 PM
Banned
Hmm, well after changing by belt out, im seeing 10-11 with a 4# lower. This isnt right. I was nailing down 12-13 on the dyno 2 weeks ago. I wonder if the belt is fockin slipping?
Old Mar 21, 2003 | 04:20 PM
99svtlightning's Avatar
The gauges are usually close enough. I would guess you are losing boost somewhere, but you never know.
Old Mar 21, 2003 | 05:14 PM
JeffsLightning's Avatar
Maybe you need this ****....
Old Mar 21, 2003 | 08:59 PM
Banned
Yea, im going to try that next. I want to run down the exhaust system first. I also want to check to see if the TB is opening all the way when the pedal is to the floor. I have seen instances of mustangs that need the throttle cable shimmed to fully open the TB.. If that doesnt work, the the metco is going to be ordered.
Fockin truck!
Old Mar 21, 2003 | 11:57 PM
Spritle's Avatar
Mine reads correct. 23lbs on the Coupe.
Old Mar 23, 2003 | 12:08 AM
TINNMAN's Avatar
Hey, Im stock (have open air stack filter though) and just put in my guage. It read 10#'s when at wot tonite. Is this common from an open air filter element being the only mod? Also, it was like 35 degrees outside, is 10#s possible with that scenario? Thanx
Old Mar 23, 2003 | 12:13 AM
Banned
Found the problem. My right side cylinder head towards back is leaking oil.. Looks like she lifted. Going to Ford next week..
Do they resurface the head or use a new style gasket?
Old Mar 23, 2003 | 12:57 AM
Tim Cowley's Avatar
My boost gauge has never worked right. I sent it back and got another and it still reads 18 on a #4 pulley. **** my head pulled also. Maybe cause I was pulling 18lbs on a #4! I wish! Mine is a recall gauge. 194.00 for something that hasen't read right.
