tranny upgrade
Old Mar 21, 2003 | 01:17 AM
01FordLightning's Avatar
tranny upgrade
hi i just orderd a fackor teck valve body and woul like to know which fluid to use how much to buy also where to get a tranny filter and gasket and i would like to change my pan but plan on lowering the l and dont wont cl;irence problems i really like the b&m pan but dont know which to get i also realize that the new pans usually come withe a filter but do they also have a gasket?
also if you have any picks please post them so i kan get an idea of the clierense ant shape ot the pan.
thanks
Justin
Old Mar 21, 2003 | 09:11 AM
SVT F15O's Avatar
If you don't drain the converter you are probably gonna need about 7-8 quarts of fluid. You can get a filter at any auto parts store or a local trans shop. Your pan gasket is reusable.
That is a nice sunroof you have. How much does something like that cost>??? Thanks, -Mat-
Old Mar 21, 2003 | 09:19 AM
TheRipper's Avatar
I installed the FT VB about a month ago. I didn't drain the converter and put the stock pan back on. I put in exactly 6 quarts. I would buy 7 just in case. It's kind of hard to tell right after adding the fluid where the level is. I took mine out for a nice drive, checked it again then rechecked it the next day. You will not be able to get the grin off your face after you first test drive
Old Mar 21, 2003 | 09:23 AM
SpankDog's Avatar
Banned
damn dude get it right. It's Factory Tech Valve Body.
Old Mar 21, 2003 | 10:29 AM
James-01L's Avatar
CLEARANCE PROBLEMS?
Clonetek posted this (not very pretty) pic about a month ago...
4x4 tranny pan on a lowered truck. Personally I'm not lowered and I have the 4x4 pan, I still go easy over speed bumps and railroad crossings after seeing how much it sticks down and after seeing that pic
I also did not punch a hole in my stock pan, so I have it just incase I want to go lower one day.
Old Mar 21, 2003 | 06:56 PM
alphadoggy's Avatar
Question
So which pan would you guys recommend on a 2" lowered truck, this one
http://Lightning-Enterprise.com/FMStranspan.html
Or this one
http://www.lightningforceperformance...productID=1037
