Finshed intercooler pump switch
I finished installing my switch on the intercooler pump. I just put the wire on the ground on the relay in the fuse box. I didnt cut anything. Then i simply put the switch in one of those holes on the fender.
Originally posted by Daves00L
thanks for post. much easier and safer than messing with PCM harness ground.
The other wire goes down to the pump.
You are realy just ading some wire and a switch to the loop.
Did you get a three way switch with an intermediate position so it will run at normal times.
I dont want to have to remember to turn it on everytime i start the car.
My setup runs the one wire from the relay to the switch then to the ground on the frame. i only used about 12 inches of wire for the whole setup.
things needed:
switch
wire 14 awg about 1 foot long.
Key must be in ON to make pump work
things needed:
switch
Pics please. -Mat-
