Anyone One Know How Many Degrees Timing A Stock L Has @ WOT?
Old Mar 6, 2003 | 07:29 PM
HANKFAN's Avatar
I am curious if anyone knows how many degrees timing does a stock L have at WOT?
Old Mar 6, 2003 | 08:32 PM
cyntaxx's Avatar
i'm curious as well...
Old Mar 6, 2003 | 08:33 PM
LightningTuner's Avatar
I know.
Old Mar 6, 2003 | 08:36 PM
cyntaxx's Avatar
do tell
Old Mar 6, 2003 | 08:38 PM
Sorry Brian, I just had to mess with you after that other post
Stock 99-00s max out at 14 degrees total at 5k rpms.
Stock 01-03s max out at 11 degrees total at 5k rpms.
Keep in mind there are many other tables and functions in the calibration that also affect timing, so it can be higher or lower than that based on other variables. Example is the PCM adding timing when it gets colder.
Hope this helps.
Old Mar 6, 2003 | 08:39 PM
HANKFAN's Avatar
Thanks Sal!
Old Mar 6, 2003 | 09:15 PM
camcojb's Avatar
I've built several blown and turboed engines, but they've all been Chevy's. The last engine I had was a centrifugally supercharged 540 that used 26 degrees total timing with 15 psi of boost, no intercooler, and 91 octane pump gas. And that was a safe tune! I'm guessing the Ford head design just requires a lot less timing. There were a couple of late model Mustangs with centrifugals that had to be cut back to 20-22 degrees of timing to avoid detonation, which really cut into their power.
It just really caught my eye seeing that low amount of timing. You do that to a standard small block Chevy and you'll absolutely kill the power.
Jody
Anxiously awaiting the arrival of my Sonic Blue Lightning
Old Mar 6, 2003 | 09:39 PM
LightningTruck's Avatar
camcojb
Just looked at your project cars. WOW you are my idol!
Old Mar 6, 2003 | 09:44 PM
VINNIE's Avatar
Originally posted by LightningTruck
camcojb
I got dibs on the Red one.
SWEET COLLECTION!!!!!!!!!!!!!!
Old Mar 6, 2003 | 11:59 PM
camcojb's Avatar
Thanks guys. Just a hot rodder myself. Most of my experience has been with Chevy's but I love anything that can be modded. Already got a pulley, 4-way chip, thermostat, cold air package, front springs and rear shackles on the way and I don't have the truck yet!
This has been a great source of info for me on the Lightnings and appreciate the help I've received from you guys. I've been spending a lot of my spare time reading older posts and trying to sort out what mods I want and/or need. I was shocked with the timing specs of these trucks and obviously have a lot to learn.
Thanks again.
Jody
Old Mar 7, 2003 | 02:05 AM
cyntaxx's Avatar
why the difference between the years?
Old Mar 7, 2003 | 02:16 AM
speeder's Avatar
Question
Hey Sal
Why do the 01-03s have less timing than the 99-00?.
Larry.
Old Mar 7, 2003 | 03:10 AM
ecm747x's Avatar
I have been told as well from 2 tuners that after 104 mph 4 deg of timing is added as well......
Old Mar 7, 2003 | 06:43 AM
Rob_02Lightning's Avatar
Originally posted by LightningTuner
I know
"11 is correct"
