locating all L
Old Mar 4, 2003 | 04:51 PM
KINGPIN's Avatar
This is the passenger side picture you took of the shackle.
Take the same picture of the driver's side so we can see if they're both installed the same.
Jeff
Old Mar 4, 2003 | 05:12 PM
Konig's Avatar
am I crazy or does that look stock to anyone else?
Old Mar 4, 2003 | 05:19 PM
KINGPIN's Avatar
That shackle looks too long to be stock. Maybe the stocker is on the driver side and that's why it's leaning.
Jeff
macracer18's Avatar
is this a good enough pic
Old Mar 4, 2003 | 05:21 PM
macracer18's Avatar
please tell me you are joking and please help me
Old Mar 4, 2003 | 05:23 PM
macracer18's Avatar
do i need to take another pic of the driver side where its more of a level pic so you can see the size better
Old Mar 4, 2003 | 05:28 PM
Konig's Avatar
I dunno...they look the same side vs. side. Would a rear shock being shot cause that lean? Im guessing the front suspension hasnt been messed with?
Old Mar 4, 2003 | 05:30 PM
KINGPIN's Avatar
The shackles look like they are the same style / length and they look to be installed correctly. Look at this picture from your gallery.
That front spring hanger is bolted on instead of riveted. It's definitely not stock. Looks aftermarket to me. Take a picture just like that of the driver's side to see if it is the same style hanger.
Jeff
Old Mar 4, 2003 | 05:38 PM
blowntruck's Avatar
Maybe they took a leaf out of the spring?
Your sunroof is awesome!!
Old Mar 4, 2003 | 05:40 PM
macracer18's Avatar
is this good
Old Mar 4, 2003 | 05:42 PM
Konig's Avatar
this is so odd....did you count the leaf springs to see if the match from side to side? If not then that only leaves the rear shocks. If its not them then it has to be something up front
Old Mar 4, 2003 | 05:43 PM
macracer18's Avatar
thanks
Old Mar 4, 2003 | 05:46 PM
KINGPIN's Avatar
Good idea about counting the leafs. I would suggest getting it on some flat level ground and taking measurements at all four wheels. Measure from the center of the wheel to the fender lip and the fender lip to the ground. How does it drive? Any pulling to the left or right?
Jeff
Old Mar 4, 2003 | 05:47 PM
macracer18's Avatar
there is five on both sides please don't give up on me
Old Mar 4, 2003 | 05:49 PM
macracer18's Avatar
it drives fine straight and everything
