Did the swap....
Old Mar 3, 2003 | 09:35 PM
WHOZNEXT's Avatar
Did the swap....
Just did the swap to HD rims -
On the scale factory L wheel = 65lbs
HD rim with stock tire = 79lbs
The whole combo is about 1 inch taller.
What tire pressure should be run in these tires?
Is the added wieght more of a factor than the added height (in relation to the overall affect on gear ratio)?
I can't tell but maybe a little less accelleration, not sure but definitely can tell it in steering feel, maybe this will go away with a lower profile tire - anybody know?
Do like the way it looks though!!!!!
Old Mar 3, 2003 | 10:55 PM
blowntruck's Avatar
I run the tires at 35psi.
I never noticed any acceleration change but they are heavier for sure. The speedo will not be too far off man.
PICS!
