Time for some slicks
Old Mar 3, 2003 | 05:40 PM
Hilander's Avatar
I did a search and there are so many conflicting posts, So i was wanting to know what kind of drag rims everyone has and what kinda slicks to go with them.
I wont be using them every weekend but when i do go to the track i would like to be able to hook.
If anyone has ideas of were to get the rims and slicks i would really appriciate it.Pics would be great.
p.s I am going for the 16X10s so i dont have to grind the brake calipers.
Thank's
Old Mar 3, 2003 | 06:01 PM
Don's Bolt's Avatar
I see you have a 2000
If you still have the 3:55 rear end gears you might want to look at the Mickey Thomson 26 x 11.50-16 ET Streets.
This will bring your gear ratio down close to 3:73 when you are at the track.
If you swapped the rear end gears for 3:73 go for the Hoosier 28x10-16
Old Mar 3, 2003 | 06:02 PM
Suavy's Avatar
I use Eagle Alloy's 16 X 10 and Mickey Thompson ET Streets 26 X 10 X 16
They work great! Going to work even better with JLP lift bars!
Peace, Suavy
Old Mar 3, 2003 | 06:34 PM
03LightninRocks's Avatar
Weld XP draglights 16x9.5 Wheels
Hoosier 28x10-16 Slicks
Rocks
Old Mar 3, 2003 | 06:53 PM
Hilander's Avatar
Thank's guys,And yes i do have the 3.55s. Were is the best place to get these?
Old Mar 3, 2003 | 07:01 PM
Don's Bolt's Avatar
Try Summit or Jegs, they also may be a good place to get the rims.
You may want to ask guys who run the M/T of they run tubes or not, I run Hoosiers and don't run tubes
Old Mar 3, 2003 | 07:24 PM
LIGHTNINROD's Avatar
M/T ET Streets--26x11.5x16" on ARE Baja 16" wheels--no tubes, no screws got me into the mid 12s. Try them at 20 psi--cold.
Dan
Old Mar 3, 2003 | 07:29 PM
B4THNDR's Avatar
Don
What kind of rear drag wheels are you running?????
Mike
Old Mar 3, 2003 | 07:42 PM
Don's Bolt's Avatar
Re: Don
Mike
Last year I ran Hoosier 28x10-16 on Eagle Alloy wheels
This year I got a set of lightweight Bogarts to replace the Eagle Alloys.
Old Mar 3, 2003 | 07:57 PM
Hilander's Avatar
Hey Don, Were did you you get your Bogarts from? and also what type are they?
Sry for all the q's but can't hook anymore lol
