need info in air filters
hello i have a 2000 ford lightning and i would like to know what are the best air filtres to buy that will give me the most hp and how do i put my truck pic on here
Re: need info in air filters
Check the FAQ for image posting instructions.
Some guys have cut holes in the bottom of the OEM box or taken the bottom of the box off completely and then replace the OEM with a K&N filter. Some have added flexible hose(s) from the box to the grill to feed cooler air to the filter.
I chose to use PSP's Fast Air kit:
http://www.powersurgeperformance.net...+and+Breathers
Dan
Dan
All of the air induction engineers I know say to stay the hell away from K&N so that is what I will do. Going with an open filter design is poor because of it will just soak up heat. I am looking to replace mine with something to stick in the air box. I have the question out to my friends, and I will let you know what they say...after all they do this for a living.
ok so all i have to do buy a $179 hi flow kits and thats it i am done or do i have to buy othr things to make it work and/or do i have to cut holes and stuff and if i buy a 90mm MAF upgrade will it put me at 380 like the 01's or more
Since you're still unsure what to do, I would do some 'searches' and/or more reading about mods to your 2000 L. Good luck.
Dan
i purchased a used airraid off e-bay for my1999L. you could hear the supercharger more but i dont think it made any difference in power. i then bought a 90 mm mass air off ebay and had to got an aluminium adapter ,new air filter and alter air raid box so 90 mm would adapt to it. i havent got a chip yet and it does run better by the seat of my pants. it would probably be better to just do an air filter and 90mm threw a vendor and not screw around like i did. but you will need a chip to be safe from what i am told and it all adds up real quick.
ok i will try something i don't know yet i am really knew at this well in fact i know nothing about them yet but hey got to start some where its just i have no idea what to look for and where thanks for all of the help
