Making your own electric fan setup...........
Old Mar 2, 2003 | 07:19 PM
JoeLightning's Avatar
Thumbs up New Question
Thanks soap!!!
According the fordpartsonline.com, the fan does list for $232.25 (as soap mentioned), but fordpartsonline.com sells them for $137.96! Not a bad deal for an OEM quailty fan.
Soap, I'm thinking about adding this to a car project I'm working on - not my Lightning. Do you happen to know any of the fan's external dimesions? Like, how thick from motor face to shroud face? 5 inches?? How about the outer diameter after the mounting structure was removed? 22 inches???
Thanks again!!!
Old Mar 2, 2003 | 07:31 PM
soap's Avatar
Re: New Question
After trimming the excess plastic for mounting to a 4.6L the OD of the fan was 19". Blade size is 18". The thickness of mounting surface (where you can attach a bracket) is 3". I am not sure of the total thickness (including motor) of the fan but would say your 5" guess is about right.
Let me know if you need anything else.
--Joe
Old Mar 2, 2003 | 07:35 PM
mecca's Avatar
soap,
AWESOME! For people like me who rather do their own work to their truck, to know that they put all the hard work into making it fast, this is an awesome write-up. Not only am I gonna save money, but I can easily build my own setup. Thanks a lot!
-Mike
Old Mar 2, 2003 | 07:51 PM
Chainsaw13's Avatar
From: Cuttin' Heads with Jack Butler at the CrossRoads!
You are going to post this over on the Miloc board aren't you?
BTW, thanks for the writeup.
Old Mar 2, 2003 | 08:02 PM
RAN JR's Avatar
Originally posted by soap
Once everything is in place you can wire it up.
We spent about $15 at Home Depot for hardware and $35 at Autozone for wiring (fuses/fuse blocks/relays/wire/connectors/switches). The entire job took an afternoon including shopping and only ran his $155 for everything.
Hope this helps some of you guys that did not know how to get from point A to point B.
--Joe
I'm thinking of doing this but have no idea of what kind of wiring and so on I need. Can you list out the wiring and fuses, etc..... needed for this project. And also does it just run all the time or does it kick on at a certain temp. If you could just explain the wiring side to me a little better I would very much appreciate it.
Old Mar 2, 2003 | 08:04 PM
soap's Avatar
Send me an email to sopoliga@hotmail.com and I will reply to it.
--Joe
Old Mar 2, 2003 | 09:10 PM
cyntaxx's Avatar
great writeup soap. also, about that variable speed thing...i checked and mine is a single speed....but it was only $130..
so if someone wants to shave some $$$ off even more....
Old Mar 2, 2003 | 09:32 PM
soap, Thanks for the providing those dimensions..... Joel
Old Mar 2, 2003 | 11:29 PM
Splash7285's Avatar
how do those brackets mount to the fan and the shroud, possible pics of that??? ......... NICE write up!!!
Old Mar 2, 2003 | 11:47 PM
LatemodelRacer2's Avatar
Will this fan work 10 blades not shure the cfm though.
Old Mar 3, 2003 | 09:00 AM
soap's Avatar
That is one monster fan........I'll bet that things moves like 6000 cfm.
Technically anything will work it just depends on how good you are
--joe
Old Mar 3, 2003 | 05:47 PM
soonerlightning's Avatar
that is one of the best how to posts i have ever seen.
Old Mar 3, 2003 | 09:19 PM
It came off my race car when i wrecked last year. the car was totaled and this was practicaly the only thing lef t that we used.
It is a 17 incher on the outside tp putside.
Old Mar 3, 2003 | 09:31 PM
grinomyte's Avatar
couple questions. why the heck doenst ford just use electric fans from the get go. I mean milage is important obviuosly for their vehicles. This seems pretty cheap to me. Also how much hp gain do you guys in the L's pull from this mod? For the regular f150 4.6 i hear 18 but i imagine it has to be quite a bit higher for you guys at the top end.
Old Mar 3, 2003 | 09:52 PM
soap's Avatar
18 ***** I need to get a 4.6L. It frees up like 5-10rwhp on an L.
--Joe
