OK, I measured the angle of the dangle and ...
Old Feb 28, 2003 | 03:26 PM
SVT_KY's Avatar
Thanks to my GOOD friends at the Tates Creek Valvoline (It's
a LOT dryer INSIDE today!) I have measured the driveshaft and
pinion angles. The pinion is n u t s on at 0 degrees, and the
driveshaft is 1 degree slope up towards the engine.
This sounds pretty close to perfect, IMO, what do y'all think?
Anyone know what the stock ones measure?
TIA ... Cliff
Old Feb 28, 2003 | 03:41 PM
NeedFourSpeed's Avatar
Re: OK, I measured the angle of the dangle and ...
Originally posted by SVT_KY
n u t s on
TIA ... Cliff
Old Feb 28, 2003 | 04:01 PM
Actually, I think ICULUKN is a good resource for angle of the dangle questions. Some angle will give you better launches but I don't know the specifics.
Old Feb 28, 2003 | 04:10 PM
soap's Avatar
Actually I thought a fella by the name of Holmes would be a better source of info.
--Joe
Old Feb 28, 2003 | 04:15 PM
--Joe
Would that be Johnny "Wad" Holmes .
Old Feb 28, 2003 | 04:51 PM
RTKILLA's Avatar
did someone say dangle????? oh angle of the dangle, yeah well thats classified information.
Old Feb 28, 2003 | 05:17 PM
Crued's Avatar
The angle of the dangle is inversely proportional to the beat of the meat.
Old Feb 28, 2003 | 05:42 PM
f150ldc's Avatar
The way this thread is going it will be closed soon. Starting to get to much information.
In fact, since the new baby there has been no angle or dangle
Old Feb 28, 2003 | 06:40 PM
quiksilver's Avatar
SVT KY: So you've got 1 degree negative, with what mods to change this from stock?
I lowered mine with 2" shackles (rear only) and haven't measured it yet. Kinda hoping for 1 to 2 degrees neg. from the change.
Old Feb 28, 2003 | 08:18 PM
SVT_KY's Avatar
Full ROUSH lowering + 1" of rear shackle. Even steven on the
lowering 16.5 inches CL to fender rim.
I thought that I would see more, but 1 degree seems very small
compared to the shims that I see some people using (4 Degree?)
I am not sure what the negative means ... The back
of the driveshaft is lower than the front ... If that's negative
then that's what I have a 1 degree slope down toward the
differential. The differential is dead vertical.
I think if the back "squats" on launching with slicks, it would
make the angle less negative, right? So you would have to
"preload" a certain amount of negativety? Have I got that
right?
Thanks ...
