Swappin rear tires for track
Old Feb 26, 2003 | 11:25 PM
LatemodelRacer2's Avatar
I have heard from a few people this helps. Putting the LR on the RR.Anyone tried this. Whats a good air pressure for F1's at the track.I run stock psi31.
Old Feb 26, 2003 | 11:31 PM
03LightninRocks's Avatar
I had pretty good luck running them at 25lbs.
Rocks
Old Feb 26, 2003 | 11:36 PM
Black2000L's Avatar
I dont know about putting the Left Rear on the Right Rear, ever try stepping on it while in reverse, the F1's do not grip at all.
PS If this is what you meant by LR and RR.
Old Feb 26, 2003 | 11:44 PM
I meant putting the RR on the LR and the LR on the RR. I see your point. It is testNtune this sunday so ill give it a sot one run and see. What is the lowest psi i should go down to in search for traction?
Old Feb 27, 2003 | 12:57 AM
cpeapea's Avatar
i dont believe in that swapping crap, they were designed that way for a reason mostly wet water traction, but they definitly werent meant to grab in reverse direction
Old Feb 27, 2003 | 01:09 AM
Black2000L's Avatar
I know mine do not grip for their life when i floor it in reverse. I would not try it. That why they are directional tires. Like cpeapea said, they wer enot engineer to grab in that direction.
Old Feb 27, 2003 | 01:11 AM
PhillipSVT's Avatar
you could take your fr and put on rr and take lf and put on lr.
no joke, if you haven't rotated, the fronts might have more bite.
Old Feb 27, 2003 | 02:24 AM
Suavy's Avatar
Just get som Mickey thompson ET Streets
Peace, Suavy
Old Feb 27, 2003 | 07:10 AM
mecca's Avatar
Peace, Suavy
Yeah.......
-Mike
Old Feb 27, 2003 | 08:44 AM
Six Spd Z28's Avatar
Registered User
Where are you going? Steele maybe?
