Help!! My beater's got a problem!
Old Feb 26, 2003 | 08:13 AM
SilverStreak02's Avatar
Exclamation Help!! My beater's got a problem!
Went out this morning and started my car. It's an 88 Oldsmobile Calias. I let it run for several minutes. I went back out to go to work. I get in, turn on my headlights, and as soon as I turn on the heat the car just dies. The enginge stopped running. However the headlights were still on. I turned them off and went to restart it. NOTHING. Not even a small crank. The entire electrical seems dead.
Anybody have any ideas as to what could be happening? Winter is not over yet, so I don't really want to dig the truck out.
Any help would be appreciated.
Thanks,
Old Feb 26, 2003 | 08:38 AM
cabraco's Avatar
Could be just a bad battery, go to a battery store and get a free load test. Try jumping it or put a battery charger on it for a while, see if you can get it started. If its been cold out the cold will sap any strength left on an old battery. Also put a volt meter on your alternator, should be putting out at least 14 amps.
Old Feb 26, 2003 | 08:40 AM
LIGHTNINROD's Avatar
When you turned the heater on, did that turn the heater fan on too? If so, you may have a 'dead' battery that finally gave up or the battery cable's clamps may be corroded. Check the clamps and posts first.
If that's not it, I would 'jump' the battery with a good one and then(if it will run--keep the lights and fan off) drive it to an Auto Zone(etc.) and get them to do a 'load' test on the battery and alternator.
Dan
Old Feb 26, 2003 | 08:43 AM
Thanks, for the help guys. I kinda had an idea that the battery was probably the culprit. Again thanks.
Old Feb 26, 2003 | 09:45 AM
THEAUTOMAN's Avatar
Sounds like your altenator is bad. I would probably replace the battery too because a bad batt can take out the new alt. GM altenators suck.
Old Feb 26, 2003 | 11:34 AM
Scott Dunn's Avatar
Check the pos. battery cables GM's are bad about corrosion there
and can produce a no crank condition as well as not returning the charge back to the batt.! Hope this helps
Scott
Old Feb 26, 2003 | 12:07 PM
VyPeR's Avatar
is it possible that maybe the fan froze up and blew a big fuse of some sort? OR maybe your A/C compressor died and locked up... those usually come on with most cars whether you use hot or cold for dehumidifying/conditioning purposes
just a thought
Old Feb 26, 2003 | 08:50 PM
LightningTruck's Avatar
Check the connections at the starter, find the Fuseable link, check it with a volt meter.
Old Feb 26, 2003 | 09:14 PM
LatemodelRacer2's Avatar
my beater blew up in december so i have been driving the L every day. It has its ups and downs driving it every day.
