wheel change - pros and cons??
Old Feb 27, 2003 | 10:22 AM
VINNIE's Avatar
Considering you are going from an 18 inch to a 20 of course they are going to be heavier.
Stock 99/00 w/ tire was 62 lbs (18 inch)
Your 20s will be 83 lbs.
I run 01/02 20inch replicas and ran an 11.92 with them on the front and a 1.59 60 ft w/them (heavy a$$) 20s on the front.
So get the Harleys and do not worry and have fun.
The only possible negative would be faster wear on the bearings and faster wear on the brakes with the added rolling weight.
VINNIE
Old Feb 27, 2003 | 02:55 PM
HIVOLTAGE's Avatar
Looks like that it won't make to much difference for someone who just runs the truck on the street and doesn't drag it. I think the HD's look good on the trucks. Are the lugs size and spacing the same from the HD to the L's like 01-02 years? + are those 295's you talked about speed rated to what?
Old Feb 27, 2003 | 03:25 PM
captainoblivious's Avatar
Originally posted by QuickBrick
I’m still trying to understand the principle of wheel weight verses truck weight. ...
Rims/tires are unsprung weight. Adding 1 pound of unsprung weight is like adding a few lbs. of sprung weight to the vehicle. I don't know what the rule of thumb is, but lets say hypothetically for the sake of easy math:
1lb of unsprung weight = 2lbs of sprung weight.
So if you replace a rim/tire combo that ways 40lbs with one that weighs 80lbs you are adding 40lbs per wheel x 4.
So thats 160lbs of unsprung, which would equal 320lbs of sprung weight.
Hopefully someone else could explain it better and give a better estimate of what it is.
edit for link on more info:
http://corner-carvers.com/forums/sho...light=unsprung
Old Feb 27, 2003 | 03:48 PM
HIVOLTAGE's Avatar
Is there a simple mod for a stock L that would compensate for lost acceleration or will it be to little to tell?
Old Feb 27, 2003 | 03:58 PM
blowntruck's Avatar
There is more weight. But I could never tell.
Old Feb 27, 2003 | 04:46 PM
WOTtheL's Avatar
Tom,
Why would you want to cluter your nice truck up with those REALLY heavy and clunky Foose rims? Please let me know where you will put them, and I'll arrange to have them picked up.
Forrest
Old Feb 27, 2003 | 05:26 PM
WHOZNEXT's Avatar
who is Tom? I think the rims look AWESOME.
Old Feb 27, 2003 | 05:44 PM
QuickBrick's Avatar
Captainoblivious thanks, the explanation and link helped…
Originally posted by WOTtheL
Tom,
Why would you want to clutter your nice truck up with those REALLY heavy and clunky Foose rims? Please let me know where you will put them, and I'll arrange to have them picked up.
Forrest
lol, don’t hold your breath waiting for that one buddy…
Tom
Old Feb 27, 2003 | 06:48 PM
cyntaxx's Avatar
if you're not going to drag race or do autoX, get what you want. 18 inch or 22 inch, as long as the tire isn't too tall you'll just be out money. the loss in acceleration you can make up with a simple bolt-on..or more since you have the $$$ to bling.
