Nowhere to Go, Why not check my plugs...DOH!!!
Old Feb 26, 2003 | 08:39 PM
  #31
cyntaxx's Avatar
Originally posted by EZGZ
6. 7 Our Fathers and 7 Hail Mary's and $5 in the poor box at church.
I've used this one before...works on everything from launched plugs to broken rods...
Old Feb 26, 2003 | 08:43 PM
  #32
SVT_KY's Avatar
Cross threading those seems REALLY easy ... Maybe it's the
soft aluminum, huh?
I heard that you should use a "thread chaser" and not a tap
for the first attempt to staighten out the problem.
Trouble is there is soooooo little room in there ... I had to
do two of mine after I took my plugs out the first time. You
don't wanna know who cross threaded them <grin>
Old Feb 26, 2003 | 08:46 PM
  #33
SpankDog's Avatar
Banned
Oh yea me too.......but on the way out.
Old Feb 26, 2003 | 10:58 PM
  #34
theperfectstorm's Avatar
__________________________________________________ _
Posted by 03Lightnin
Not really...I did drop a socket into the #8, but I fished it out with my magnet. It had me swetting bullets for about an hour.
And I thought I was the only one in the whole world who had
done that! Mine was a deep set (long) 7MM, and was a SOB
to fish out.
Old Feb 26, 2003 | 11:39 PM
  #35
03LightninRocks's Avatar
soft aluminum, huh?
Well that's two thread chaser votes. Thread chaser it is! I'll try when I get back home next week.
Rocks
Old Feb 27, 2003 | 08:41 AM
  #36
tliss's Avatar
I may have to try the thread chaser idea. I was also considering trying to pull it out "Bob Vila" style with one of those Craftsman damaged screw removers. I'm not giving up on it yet, but I may soon. My damn hands are all chewed up and sore as hell! That #3 plug on the passenger side is a tight fit; and you know what they say about guys with big hands
they have a hard time working in the tight spaces on the engine!
For the ladies...you may now !!
Tom
Old Feb 27, 2003 | 08:48 AM
  #37
tliss's Avatar
Broken Bolts and screw are always tuff but I have been successful most of the time.
Your problem is that it is below the surface and hard to get at.
But! still not impossible.
The important thing is to not give up and just keep trying different things Mcgiver style.
Let me just throw out some ideas and it might spark your mind!
1.A Dremel tool to make a straight slot to get a screwdriver on.
2. Use a burr style grinder to make a recessed center so you can drill it.
3. This is not a good one but it could be used to drive something like a torx bit into the hole to get a grip http://www.harborfreight.com/cpi/cta...emnumber=37530
4. Take a nice fat arch welding rod 1/4 inch and set your arch welder on say 60 amps or so and strike an arch on the top of the bolt and let it stick. Then release the rod from the holder. If it sticks good you may be able to twist it out. Be sure to let the bolt cool completely because metal expands when it is hot and that will make it harder to get out.
Caution!!! Disconnect your truck battery and turn on head lights to drain and current. Also connect your ground on the welder close so no electricty is going where you don't want it.
use common sence and caution around gasoline or other flamables.
5. Soak the area where the bolt is with WD-40 or liquid wrench for a while. Strike the bolt with a hammer and punch to jar it and allow the oil to get in the threads. Go along the outside edge with a sharp drift punch in counter clockwise direction.
7.
8. Take the manifold off so you can work on it.
9. Pay someone else to do it.
I'm considering a few of your ideas next time I decide to try to get in there. I think I'll stay away from trying to weld anything, as my expertise does not stem into welding (I have a better chance of welding my butt cheeks together that doing that right) . I was considering the notch/screwdriver idea, but I figure I'll probably snap what I have left of the bolt in half and end up having to go to #9 anyway. I'm considering the torx bit, but we'll see. #6 and #7 have been tried, but when I'm done I still go out to the garage and the bolt hasn't been removed; besides, I hear the engine doesn't like beer anyway! And, of course, paying someone else to do it is always an option!
Thanks for the suggestions!
Tom
Old Feb 27, 2003 | 05:33 PM
  #38
clonetek's Avatar
i broke the 3rd one off on the drivers side the first time i changed my plugs... i'm still wondering how to get it out.
Old Feb 27, 2003 | 08:55 PM
  #39
hapynzap's Avatar
Are you guys using any wd40 or anti sieze before putting these bolts in?
Old Feb 27, 2003 | 09:05 PM
  #40
cyntaxx's Avatar
cant use antiseize...
Old Feb 27, 2003 | 09:22 PM
  #41
SpankDog's Avatar
Banned
WHy cant you use anti-seize its made for things that go into aluminum.
Old Feb 27, 2003 | 09:43 PM
  #42
tliss's Avatar
Looks like I might have an answer. clonetek, next time you're in the Dallas area you may want to hook up with one of the TALON guys, Tony2000. He and his dad operate a shop and he told me today he could work this thing out for me. I'm going to hit him up next week to see what he can do. I'll let you know.
Tom
Old Feb 27, 2003 | 10:03 PM
  #43
clonetek's Avatar
maybe i'll give them a shot when dallas thaws out..
Old Feb 27, 2003 | 10:26 PM
  #44
droptail's Avatar
Try a penetrant and reinstall with anti sieze, may help prevent some stripping, and eases extraction.
Old Feb 27, 2003 | 10:32 PM
  #45
cyntaxx's Avatar
whoops i was thinking the heads and was told antiseize wouldn't work and not to use it? i forgot the exact reason..maybe i'm just talking out of my a$$ (probably it)
