cfm ratings of electric fan........
Old Feb 24, 2003 | 04:11 PM
soap's Avatar
Question cfm ratings of electric fan........
What are the cfm ratings of the electric fan most of us buy:
Ford part number.....XR3Z-8C607-AA
Both high and low speeds please.....thanks dudes
--Joe
Old Feb 24, 2003 | 07:30 PM
LIGHTNINROD's Avatar
I did a search but couldn't find anything but this will TTT
Dan
Old Feb 24, 2003 | 07:40 PM
soap's Avatar
Dan
Thanks Dan.........
I searched electric fan posts for over an hour and noone has brought it up. Just seemed funny because almost all aftermarket electric fans like Perma-Cool, SPAL etc all list thier fans by size and cfm rating.
--Joe
Old Feb 24, 2003 | 08:16 PM
Coldie's Avatar
It doesn't really matter...
Even though the aftermarket ones list flow, it's flow in an open container, not flow through a radiator.
What you'd really be interested is a chart of flow vs. static pressure generated. I'm pretty sure no one is handing that out though.
The only other thing I can add is that straight blades flow more than curved blades and metal blades typically flow more than plastic blades.
The Ford part is a curved plastic blade.
Coldie
Old Feb 24, 2003 | 08:47 PM
Tim Skelton's Avatar
Originally posted by soap
Thanks Dan.........
--Joe
From my Web site: "An electric radiator fan can offer better cooling, quicker warmups, and more HP due to the removal of the parasitic drag of the stock crank-driven fan. I chose the Flex-a-Lite unit to the right (part # 270). This $400 unit is specifically designed for the F150. It has a variable-speed fan control (60-100%) and pumps out a maximum of 5500 CFM (much more than the 3,500-3,700 provided by the Ford-based kits). Additionally, by having two fans, as opposed to the single fan in the Ford-based kits, the truck is not crippled if one of the fans goes out."
More info there.
Old Feb 24, 2003 | 08:51 PM
Neal's Avatar
Cool
HI!.... I'm running dual DERALE 16" electric fans. Each 16" fan is rated at 2250CFM, (underated) so with 2 they are rated at 4500CFM. I rarely use both at the same time. 1 works pretty well to cool my truck down. Even in 100 + degree temps.
Old Feb 24, 2003 | 09:16 PM
cyntaxx's Avatar
Soap: Since JDM and LFP and JLP all use Ford units, which are the same as ones out of Mark VIIIs, it is a 3400 cfm fan. That is what I have (home-made).
However, there are no hi/lo settings to my knowledge? I just use the switch (not AC) and it is just on/off.
Old Feb 24, 2003 | 09:18 PM
soap's Avatar
If you have the Ford fan it has 2 settings. Go look at your fan and see how it has 3 prongs. 1 is negative, 1 is low, 1 is high. Go give it a shot
--Joe
Old Feb 24, 2003 | 09:32 PM
cyntaxx's Avatar
hmmm never knew that. was this included with the wiring kit JDM, etc. offers or what? I guess mine is always on high then...
please give me more details (i didnt install the efan myself...a friend did most of it...and i haven't set up the AC controls yet)...
right now it is just the default switch...i have to go back for the painless wiring kit.
Old Feb 24, 2003 | 09:39 PM
svtdvm's Avatar
More info there.
Both the Ford-base kits and the flex-e-lite fan get the job done.
Does it really matter which fan to buy?
Is there an appreciable difference between 3500cfm and 5500cfm?
Old Feb 25, 2003 | 08:44 AM
soap's Avatar
I have no idea what the JDM (or others) wiring kit includes or how it hooks up. I wired mine myself.
Just for a test go do this:
There are 3 prongs on the fan. 1 is negative and has a - sign in front of it. 1 is positive and has a + sign in front of it. Now the other one (middle prong) is also positive. Run a test wire from the - prong to the negative on the battery. Run another wire from the positive on the battery to the + on the fan. Now move the + wire to the other prong (middle) and tell me there isn't a difference in the cfm it is pushing.
I had mine wired to turn on either high or low. One on a 30amp circuit (low) and one on a 40 amp circuit (high).
--Joe
Old Feb 25, 2003 | 09:40 AM
TimBurntire's Avatar
We sell the Flexalite unit because of its higher cfm ratings, safety (2fans instead of one), and cosmetics. No homemade brackets and such. A/c fan switch and all installation hardware included with these units too.
Old Feb 25, 2003 | 11:14 AM
Originally posted by svtdvm
. . . Is there an appreciable difference between 3500cfm and 5500cfm?
Yeah. 2,000 CFM.
Sorry -- couldn't resist.
Old Feb 25, 2003 | 12:34 PM
ShadowBolt's Avatar
Tim, please don't take this wrong but why would I pay you $499.00 for a fan I can buy from Jegs for $383.00? I must be missing something. Is there something else that is included in your kit that is not in the standard flex-a-lite kit? I really would like to know as this is a mod I am going to do in the next month or stwo.
Thanks,
Jerry
Old Feb 25, 2003 | 02:58 PM
cyntaxx's Avatar
Thanks,
Jerry
He said he paid 400...
I believe the fan in jegs doesn't include the wiring, etc.
