1/4mile safty requirements?
Can anyone tell me what type of safety devices I need
@ what speeds?
For example: four point harness, helmet, extinguisher@under 12sec. over 100mph?
I want to run the truck, but I don't want to be sent home after one pass.
@ what speeds?
If your running 12.0 and and up, all you need is a helmet and a driveshaft loop. I bet no one will even look for the loop, but I recomend one.
IHRA you don't need a cage untill 11.49
NHRA you need one at 11.99
I would still recomend a set of traction bars no matter what speed you run
1/4 mile requirements?
I'm just interested in running the truck just to see how fast this thing will actually send me down the road.
Using a G-tech meter it approx. my time@ 12.5 &114mph.
The road I drove on wasn't in service yet(new homes), but I did a terrible burnout from the launch and then when shifting gears.
I verified the mph with my spedo.
I plan on purchasing Hoosiers/Mickey et on 16"welds.
However, I don't have the option of a roll cage.
I would appreciate any advise, I by no means am any type of "MASTER OF THE UNIVERSE" and love comments/leads I can pursue.
For give me for my spelling it's not my strong point (safty).
If your truck is solidly in the 12's then you should defenitely install a drive shaft loop, and if you plan on running slicks, then a set of traction bars to keep everything straight in the rear, and help prevent drive shaft failure...Depending on where you race, the tech inspection will probably not even thoroughly inspect your truck...But if you roll up to the line and rip off an 11 something pass, EXPECT to be inspected and possibly shut down if you do not have the necessary safety equipment...Have fun!
1. Helmet
2. Driveshsft loop
3. Traction bars or links, especially since you are going to run slicks.
4. Make sure your wheel lugs are torqued(140 ft. lbs) tight
5. Way too early for a cage/roll bar
That's all you have to get but a fire extinguisher would be nice
Dan
2. Driveshsft loop
.Dan
1/4 mile safety requirements
I found a dragstrip local to me LACR in Palm Dale.
General rules that apply to most of us:
Drive shaft loop mandetory with slicks
Roll bar between 11.99-11.00
Roll cage 10.99 and quicker
if roll bar & cage apply sfi safety restraints spec.16.1
Helmet 14.00 and quicker
min 1/16 tread depth
I do run a set of traction bars that I made my-self, they are adjustable and let me set the pinion angle (not that I know what to set
My recorded G-tech run had a slow 60ft of 2.68 and a 0-60 of 5.9sec. the elasped time and mph didn't seem to make sense.
I'll try to figure out how to post the run.
).My recorded G-tech run had a slow 60ft of 2.68 and a 0-60 of 5.9sec. the elasped time and mph didn't seem to make sense.
NHRA
9.99
Gloves (SFI)
Flexplate Shield
Electrical Cut Off Switch
NHRA License
Neck Collar
NHRA Chassis Sticker
10.99
Trans Shield (SFI)
Axles (Aftermarket)
Harmonic Balancer
Window Net
Roll Cage
11.99
Protective Clothing
Roll Bar
Arm Restraints
Flywheel (SFI)
Clutch (SFI)
Valve Stems (Steel)
Bell Housing(SFI)
Seat Belts(SFI)
13.99
Roll Bar (Convertible)
Driveline Loop
Helmet (Snell 90 min)
14.00 & Slower
Catch Can
Seat Belts
Neutral Safety Switch
135 MPH
Gloves(SFI)
Roll Cage
Neck Collar
Window Net
Protective Clothing
Trans Shield (SFI)
Flexplate (SFI)
Flexplate Shield(SFI)
I took this from another website. I don't think the 10 second guys meet the rules. I could be wrong, but when was the last time you saw the tuners with aftermarket axles, flexplates, and window nets?
9.99
Gloves (SFI)
Flexplate Shield
NHRA License
Neck Collar
10.99
Trans Shield (SFI)
Axles (Aftermarket)
Harmonic Balancer
Window Net
Roll Cage
11.99
Protective Clothing
Roll Bar
Arm Restraints
Flywheel (SFI)
Clutch (SFI)
Valve Stems (Steel)
Bell Housing(SFI)
Seat Belts(SFI)
13.99
Driveline Loop
14.00 & Slower
Catch Can
Seat Belts
135 MPH
Gloves(SFI)
Roll Cage
Neck Collar
Window Net
Protective Clothing
Trans Shield (SFI)
Flexplate (SFI)
SubZero -
I wouldnt worry about PalmDale... All they check for there is a helmet..
Also, the track is at 3,000' and the air SUCKS, so I would expect to run anything other than low-mid 13's there...Especially without slicks...
I think Carlsbad opens back up next weekend, I am going to try to go down there... Its at sea level so your times are going to be much better...
-Dale
PS - go here for SouthernCali lightning peeps message board
http://www.nloc.net/socalloc
-Dale
Easter looks right on
with what I've read in NHRA rulebook. You should all get copies of the rulebook for where you run. Cost is like $12.00.
Some of what Easter lists might not apply as we have Superchargers from factory (Bellhousing?) and Auto Transmissions (Yeah-Clutch). What about Flywheel? I haven't seen aftermarket flywheels, so maybe the 'supercharger' exemption applies there
And yes, there are no aftermarket axles are there?
Happy racing.
Aren't American V-8's Wonderful????
with what I've read in NHRA rulebook. You should all get copies of the rulebook for where you run. Cost is like $12.00.Some of what Easter lists might not apply as we have Superchargers from factory (Bellhousing?) and Auto Transmissions (Yeah-Clutch). What about Flywheel? I haven't seen aftermarket flywheels, so maybe the 'supercharger' exemption applies there
Happy racing.
Right on about the air Dale, but I think it 'wheezes' not sucks.
But then again a cold night in the desert gives us a little more density.....
Enforcement is spotty. I did see a 11 Sec Chevelle get drilled for not having a bar/etc. But I've seen 10 sec Vette get by without a bar...go figure.
