Oil braether cap?
Old Feb 22, 2003 | 11:30 AM
TINNMAN's Avatar
Oil braether cap?
Are these things worth it?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6770
Old Feb 22, 2003 | 11:37 AM
ICULOKN's Avatar
Sal has them quite a bit cheaper.....
They work well.... Not as much oil blowby now....
Old Feb 22, 2003 | 11:41 AM
Rob_02Lightning's Avatar
I agree
PSP Oil Breather Cap
Price: $15.00 ea. This washable oil breather cap replaces your oil fill cap on the valve cover. Helps cure the common problem with oil injested into the upper intake and blower area. Requires chip recalibration, call us for details.
http://www.powersurgeperformance.net...+and+Breathers
Plus there's ways of fixing the problem WITHOUT a Breather
Old Feb 22, 2003 | 11:49 AM
TINNMAN's Avatar
It says chip has to be reclaibrated? What about those of us with no chip? Cant use a breather?
Old Feb 22, 2003 | 11:58 AM
I used my breather for over 5k with no reburn and no problem, however it seems SOME put them on and get a soft code.
The issue is, taken in UN-METERED air into the motor through the Breather, which in turn, makes it run Leaner. However if you have no chip, then I assume you have no Pulleys, if thats the case the small amount of air and the tiny affect it'll have on your A/F readings "should not be a concern" it's the people running right on the edge that "could" or "might" have a problem, you should be fine, I WAS, and i ran it with upper and lower pulleys without getting a re-burn.
