Hoosier 28x10x16
Start with 17 psi
First couple runs do a nice 15 sec burnout to break em in.. Then depending on track prep ( which in CA doesnt exist ) a simple 4 second haze job might only be needed. No 30 second John Force burnouts though, youre just wasting rubber.
Re: 28X10X16 Hoosier's
Originally posted by tom vandiver
I have Trucktraks and drive shaft loop. What technique do you use to launch?
I drive around the water box and back into the water, then I do a 5-7 second burnout to heat the tires up. It may take 2 0r 3 runs for the tires to really work.
I would first try to launch at about 1200 rpm's and see how they bite. If that works ok go to 13-1500 and see how that works, I launch at 1800 rpms, but I have a 2400 stall torque converter.
I use Truk Tracks, 16PSI and try dropping the PSI when I think it might help. (Notice caveat/oxymoron...'I think') Dunno yet for sure, except these Hoosiers make me more of a man than.. well...much better than F1's....
