Need help from Shaker Hood owners
Old Feb 19, 2003 | 04:45 PM
zbornac's Avatar
I took mine off to do some installs in the engine, but now I am having a few problems reinstalling it. What steps did you guys take to install/reinstall/adjust it? I am getting a little impatient of the back and forth and cjeck routine. Is there an easier way? Thanks in advance.
-Kimball
Old Feb 19, 2003 | 05:01 PM
Coldie's Avatar
nope
Just back and forth...
Make sure you mark the washers and stuff so you don't have to do it again.
Coldie
Old Feb 19, 2003 | 05:57 PM
VINNIE's Avatar
A little tip I learned from RobG. Once you find the sweet spot then mark around the washers so everytime after that it is easy.
VINNIE
Old Feb 19, 2003 | 06:01 PM
zbornac's Avatar
I was planning on marking it when I found the sweet spot, I was just looking for keys to FIND the sweet spot. Oh, well. Thanks for the info guys, you have been helpful.
-Kimball
Old Feb 19, 2003 | 06:03 PM
VINNIE's Avatar
There is only one way , trial and error.
VINNIE
Old Feb 19, 2003 | 07:00 PM
zbornac's Avatar
I just figured out why it was being such a PITA. the front driver side bolt mount was oreiented in such a way that it wouldn't allow me to move the shaker any further to the left, so I just loosened it up turned it slightly, and VOILA!!! (or however you spell it...)
Now I just have to figure out how high I want it.
-Kimball
Old Feb 19, 2003 | 07:02 PM
VINNIE's Avatar
-Kimball
I am sure you know this already , but the higher it is the less it shakes, unless you trim the gasket.
VINNIE
Old Feb 19, 2003 | 07:10 PM
FXDX's Avatar
An old body mans trick is once you've got the hood perfectly aligned and the bolts snugged down, centerpunch the hinge and carefully drill a 1/8" hole through the hinge and inner structure of the hood. A depth guide or masking tape around the bit will prevent damaging the outer structure. Once done, any time the hood is removed, the alignment holes will allow you to drift the hood into place.
FX
