Grinding Feeling At Low Speeds
Old Feb 18, 2003 | 11:18 PM
Ak.Silver2K's Avatar
Help! I am getting a slight grinding feeling through the pedals and steering wheel at low speeds, not noise, just a seat of the pants feeling-vibration. Any thoughts?
Thanks,
Mark
Old Feb 18, 2003 | 11:20 PM
whitestx's Avatar
Have you had the front pads/rotors inspected lately?
That'd be my guess without looking at it.
Good luck and let us know.
Old Feb 18, 2003 | 11:27 PM
Not many Miles
Only have 14k on the truck, and wouldn't I get that only when braking?
Mark
Old Feb 19, 2003 | 12:11 AM
Probleminfected's Avatar
i've got 18K and i've got 1mm left on my front pads.
might want to check them out
Old Feb 19, 2003 | 12:21 AM
HHHMMM
I have come down a few times from rather high speeds , guess its possible I have worn the pads a little.
Mark
Old Feb 19, 2003 | 08:54 AM
LIGHTNINROD's Avatar
mark: Because of your miles, I don't think it's your pads/rotors and you said you got the vibration feeling without braking. I think it may be in your steering gear box(not sure of the correct terminology, but it's the rusty 'box') or in your power steering pump???
Dan
Old Feb 19, 2003 | 09:23 AM
01Lightning's Avatar
Speaking of power steering pumps, do all Ls have noisey *** pumps or is it just mine?
Old Feb 19, 2003 | 09:27 AM
James-01L's Avatar
I think it is ALL FORDS that have noisy pumps.
I know my two Rangers and two F150s had em.
Old Feb 19, 2003 | 09:30 AM
4warned's Avatar
I've felt a similar problem with the steering and brakes. The dealer looked at it and it was simply from the tires that were flatspotting on the outside edges of the front tires ( only 10K miles on em ). Put em on the back and"work" them down if you know what i mean. This solved the problem for me........
Old Feb 19, 2003 | 09:38 AM
I have the same prob with my tires developing flat spots and making a "roaring" sound. For some reason it's only two. I move them to the back and "work them down" but it doesn't help. As soon as I put them back on the front the noise is back.
I originally thought it was caused by my shackles changing my pinion angle, but when I rotated my tires I realized what it really was.
Old Apr 6, 2003 | 04:40 PM
poolvibe's Avatar
Hey guys, does tire air pressure seem to change anything. I think I have the vibration you are talking about.
Just curious
frank
