For Those of you using Water Wetter
Old Feb 18, 2003 | 01:01 PM
01Lightning's Avatar
What ratio water/glycol do you run?
I think I am going to drain my radiator and refill it with a 70/30 mix and add 1 to 1.5 bottle of WW.
Also, what is the factory ratio on the intercooler? 50/50?? Would it be ok to reduce the glycol in the intercooler and add WW?
Search police: I have done a search on this but was unable to find enough info to base my decision on.
Gracias amigos!
Old Feb 18, 2003 | 01:46 PM
2002Bolt's Avatar
WW in intercooler
i just drained mine the other day and added WW. Added 1/2 bottle and the rest water. Hope this helps.
Old Feb 18, 2003 | 01:49 PM
No glycol (anti-freeze) at all?
Old Feb 18, 2003 | 05:14 PM
Fast Gator's Avatar
Iam in a little different climate than yourself, so anti-freeze is important to me.
All I know, is what I've read about WaterWetter. It sounded good to me, so I added 1 bottle to my motor radiator and TWO bottles to my intercooler
Old Feb 18, 2003 | 05:20 PM
jkbrand's Avatar
Re: WW in intercooler
Unless you've got an electric water pump, you better think
about adding something in the way of lubricant to your near 100% water volume or your pump will die prematurely.
Antifreeze has such lubricants, but there are aftermarket lubes, too.
Jeff
Old Feb 18, 2003 | 06:25 PM
KINGPIN's Avatar
1 bottle of Water Wetter for the radiator and one for the intercooler. No antifreeze, just water. Same setup I had in my last three vehicles in AZ: 01L, 00 SS Camaro, 96 Blown Mustang.
Zero problems.
Jeff
Old Feb 18, 2003 | 06:41 PM
jkbrand's Avatar
Not saying it can't be done (pure water), but it's still risky business. There will be a price to pay. Water pumps require lubrication afforded by additives in antifreeze, which also has other important additives, such as rust inihibitors.
Old Feb 18, 2003 | 07:07 PM
Neal's Avatar
Cool
HI!... I thought the WATER WETTER had added lubricants to it to lube the water pump? That's what I've always been told.
Old Feb 18, 2003 | 07:40 PM
LIGHTNINROD's Avatar
This what I use in my i/c:
http://216.239.51.100/search?q=cache...hl=en&ie=UTF-8
and one btl. of WW in my radiator.
Dan
Old Feb 18, 2003 | 09:55 PM
gtoguy1967's Avatar
i thought water pumps had sealed berings
Old Feb 19, 2003 | 07:49 AM
Hey Dan,
Did you completely drain your intercooler? and did you also put in some glycol along with the 40 below?
I plan on draining some coolant from my intercooler tank and then add distilled water to reduce the glycol concentration down to approx. 30% then add the WW.
I am going to wait on my radiator because I plan on taking the truck in for them to find out what's going on with that darn oil leak, and I have a feeling the head is going to be coming off
Sammy
Old Feb 19, 2003 | 08:04 AM
Sammy: Yea, I drained the i/c reservoir, put in 40-Below, Prestone's Rust Inhibotor(recommended by dist.?), and water. I just added WW to the radiator.
Dan
Old Feb 19, 2003 | 09:13 AM
silverSVTruck's Avatar
Thumbs up
I drained about 75% of my i/c radiator and put one bottle of WW and water in. WW's original design intent was for small dragster radiators and to be used w/ water only to help with keeping "slippery" antifreeze of the drag. WW has lubricators in it to keep your system properly lubricated.
Here's a link to redline for technical information on Water Wetter.
redlineoil.com/redlineoil/wwti.htm
Old Feb 19, 2003 | 09:22 AM
How did you drain the intercooler system? Did you siphon it out or is there a pit****?
Old Feb 19, 2003 | 09:39 AM
There is a drain on the bottom passenger side of it (my drain still had the tape on it from when the factory painted it.)
