Hey Rob02
Old Feb 17, 2003 | 05:21 AM
SLICK0478's Avatar
Hey Rob02
So I was reading you post on the PCV set up
I got so confused I figured to start a new thread
Not sure if it does not work or it half works......
Just the drivers side ---is this safe to do with NO BREATHER on Passenger side??
Or Just chit can the whole set up and leave stock --What are you gonna do????
Slick
Old Feb 17, 2003 | 06:58 AM
VINNIE's Avatar
That is what I would do, but I am no Ronbo
Old Feb 17, 2003 | 07:45 AM
Fast Gator's Avatar
There is only one **** king and he is Ronbo
Old Feb 17, 2003 | 10:42 AM
Rob_02Lightning's Avatar
Thank You, Thank You very much
Hold that thought Slick
I am sooooooo sorry for confusing people. My punishment is,
I am going to go out there "in sub zero" "blizzard conditions" in a little while (still tuning up ) and see which direction the DRIVERS SIDE ""ADDED PCV" flows in.
THAT WILL ANSWER EVERY QUESTION
Give me a while, but you'll have your answer today
Old Feb 17, 2003 | 10:51 AM
LightStruck's Avatar
Hey, I'm slightly interested too!
But don't take the cab off or anything--it's too cold for all that.
Old Feb 17, 2003 | 11:00 AM
I told you Light Struck, that was the least I could do to show that back vacum connection
Not often you get to see the other side of our Motor Right
Kind of dull looking isn't it.
My guess is, after V see's how ugly this side of our motor looks like, he will immediatly order all kinds of Bling Bling for it and spruce it all up
Old Feb 17, 2003 | 12:13 PM
I'm working on it
Old Feb 17, 2003 | 02:34 PM
Ok now I got it straight
The New PCV Valve on the PASSENGER Side (to replace the original one) is a positive type that will only allow the pressure to be taken OUT of the Motor and released back into the System, it will not allow vacum or pressure back in the Motor.
Then on the DRIVERS Side, they give you another PCV Valve, BUT THIS ONE FLOWS IN THE OPPOSITE DIRECTION. Which means the Throttle Body can no longer suck in oil, """OR""" the crankcase pressure can no longer push up into the tube.
Passenger side can only push out crankcase pressure
Drivers side can only take in
So it's settled, I DO NOT NEED A BREATHER
AND THIS SHOULD WORK PERFCT
**** the snow is getting bad, and still coming down liek a
Mo Fo
Old Feb 17, 2003 | 02:36 PM
Ahhhhhhhh, reminds me of a girl I once knew
Old Feb 18, 2003 | 05:46 AM
SLICK0478's Avatar
THANKS ROB
Thanks again
I was Confused not hard to do .....lol
I hope this works with out the use of a beather
Slick
