Has anyone blown out an axle seal?
Went to the track today. While putting on the slicks on the drivers side, i noticed some greasy juice all over the inside of the wheel.. Looked at the brake hat and sure as **** on the bottom, diff fluid is coming out. I have a blown axle seal. Guess ill add this to my shopping list... Anyone else have one?
Blown Axle Seal
Fog Lights Filled Half Way With Water
Crooked Bed
Clunk
Headlight Alignment Issues
Blown Axle Seal
Crooked Bed
Clunk
Don't think it's a common problem but I have read a few threads on this Kevin.
Here is one about it
My F150online Photo Gallery........................................My Modifications
Have a good day eh ! .................................................. .......... Dave
Yea. I couldnt heat up the slicks enough to make em stick good. As soon as i would start out in the water box, they would spin. When they began to heat up and just start to smoke a little, the diff went clunk and they would stop spinning for a second, then launch the truck 15 feet forward. Very annoying.
Track conditions were pretty bad as well.. Another Lightning i was with was cutting 1.81 60 ft times on slicks.
No ****? Did you happen to take any pics Don? Im going to crawl under the truck in the morning and see if i find anything else going on with the rear end. Im hearing weird clunky noises.
Yeah my black 99 had a leak on the axle seal the drivers side.
My 01 has already had a pinion seal leak really bad.
This was before I installed the Roush stuff.
Some where around 45000 on the pumpkin and about 30000
on the axle seal.
on the axle seal.
Originally posted by Twisted99
Now that I think about it, the pinion sela leak is probably what caused my engine to break a rod...or maybe it could have been the brass contacts on the PCM access...
LMAO..
I fought ford on my first motor in the mustang that spun a rod bearing. It was a 6 month fight.. In the end, i had to get a new top because they let the car sit outside in the heat ( vert ), dented fender from them removing and replacing the motor, scratches in the paint and of course, one hell of a lengthly fight. I did win though. This was in 2000. The whole motor cost me $500. I forced to pay for a ESP which gave me a new powertrain warranty for 36/3..
common problem on lightnings with slicks KEVIN, i allready change twice both sides,& build the limited slip case once next time i'm going to change the axles,or i'm changing the axle assy to 9 inch.
