torque specs for installing long tubes
Old Feb 15, 2003 | 11:06 AM
tallimeca's Avatar
anyone know the torque specs on the header bolts???
Old Feb 15, 2003 | 11:18 AM
mrinaldi's Avatar
Good luck with getting in there with any kind of tq wrench...Basically snug them all down evenly, get the rest of the exhaust finished, then re-check them...Drive the truck a couple of times, then re-tighten them and you should be fine.....
Old Feb 15, 2003 | 01:40 PM
easterisland's Avatar
I don't know if this helps you at all.
exhaust manifold nuts 25Mn or 18Lb-Ft
exhaust manifold studs 10-13Nm or (7.4-9.6 Lb-Ft)added that myself
taken from pg 303-01B-323 of the 2001 manual.
Old Feb 15, 2003 | 02:02 PM
captainoblivious's Avatar
What easter and mrinaldi said. Get them snug, pretty much like the plugs which are only 14lb-Ft.
I checked mine once a week for a month, then once a month for about 2 or 3 months.
